Brake Set Up?
mbuk
The Evo 2 mounts with quick release system for maguras are designed so can be used on v-brake (2 bolt mounts. To be able to use bolts then you need a 4-bolt frame which is the standard for most new trials frames. Hope this has helped (Y)
Quick release (for Evo II mounts) is so that if your rear wheel needs to be taken off you don't get raped in the arse by not being able to take the cyclinders off, best to keep with the quick release system...
How ever, you say you have a Zoo Pitbull, which i'm guessing has 4 bolt mounts?
If so, it's pretty easy to set up, just put a credit card in between the brake pad and rim and that'll be the perfect pad-rim distance, do it on both sides, tighten up each bolt evenly and you'll be done.
Edited by Fat Pants
