Magura Question
N Roach
hey,
I have a magura hs33 on the rear, and the hoosing has been put through the holes between the up and dwon tube on my GU frame. I wont the hoosing to sit on the out side of the frame.
-Can i just undo the bolt on the lever (The bolt which attaches the hoosing to the lever) and some how stop the fluid from coming out, then take the hoosing out through the frame?
or, Is this not possible?
cheers
nafan :)
You could do that and then pump a tiny bit of oil in the slave cylinder almost like a tiny bleed to get rid of the minimal air that might be there. (I think)
EDIT: Or do what XPbIM3 said, they're basically the same principal.
Steve
Edited by steve1rc
