Forks And Weels
hi guys,its peter bailey,just wondering,i use to have a complet onza t-magwith guy forks,and a intergrated headset,will my forks fit onto a zoo python frame,and.........................will my back weel fit? thanks guys
peterjamesbailey
hey i would recomend try-all rims and zoo pitbull forks, if you are riding mod then i would recomend try-all rims and onza tough guys
how i have helped
ben
hey for the forks i would get your self some echos there good and strong mine have been going nearly a year and a half now and ive punished them bad :lol: and for your rims get yor self a rear chris holmes rim they are as strong as a try all rim but hold as gooder grind as a ronnie rim does. i am not quite sure where to get the rims from i am in need of geting one my self does any one know where i can perchase one of these rims???
all forks and hubs are the same size for ether 20 or 26.
chris
Hi,
the forks and wheels should fit, it may ride strange because the onza forks look much longer than normal ones. it may change the geo but i am not 100%. just builtd it up and ride it (Y)
moza
Edited by moza
wheel will fit dont worry may wont to get some snail cams for it instead of chain tugs, and forks may fit depending on the lenght of the fork tube , i THINK most of dengs headtubes are longer then onzas...........
hope iv helped padarik
Forks will fit. The vast majority of trials forks are 1 1/8"
Back wheel will also fit but as said you may want to buy snail cams for tensioners as the python doesn't have very long dropouts.
But yes, both will fit. Its amazing to see that it was only moza who was the first to actually answer the question....
how i have helped
ben
:blink::blink::blink: Ben Ben Ben :rolleyes::rolleyes:
Would i not be correct in saying that onza tuf guys are 26inch forks only. Ben how can you recommend them after you have seen what have happened to mine.
but urs may have been bashed around alot before you got them and tom has tough guys on him onza
