trials wannabe Posted January 4, 2007 Report Share Posted January 4, 2007 hi as you can tell its to do with my gearing its hard to explain it but il give it my best shot. its single speed but still has all the cogs that it would have and a derailier (rear mech) and at the moment the chain keeps slipping down and going into a higher which infact is really dangerous as i earlier found out. is there anyway of stopping my chaing from doing this ... ? more information on request thanks Quote Link to comment Share on other sites More sharing options...
flas12345 Posted January 4, 2007 Report Share Posted January 4, 2007 himake sure that your chain is inline with the front kog because if it is not, this is what could be causing it or it maybe that your chain is to slack and needs a link taking out, or also it could be that you gearing is not set up properly therefore you need to set them up.hope iv helped. Quote Link to comment Share on other sites More sharing options...
(chief) Posted January 4, 2007 Report Share Posted January 4, 2007 (edited) himake sure that your chain is inline with the front kog because if it is not, this is what could be causing it or it maybe that your chain is to slack and needs a link taking out, or also it could be that you gearing is not set up properly therefore you need to set them up.hope iv helped.What he sed really just check that the cog is in line and that the chain isn’t to slack also that every thing looks to be set up properly.chris Edited January 4, 2007 by (chief) Quote Link to comment Share on other sites More sharing options...
moza Posted January 4, 2007 Report Share Posted January 4, 2007 Hey, is there any sort of chain tensioner on your bike?, what is the chain tension?what is the chain line like?what state is the cog you use in, how worn is it?i would recomend getting a single cog on the rear and some spacers, this will sort a chain line problem.Moza Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted January 4, 2007 Author Report Share Posted January 4, 2007 Hey, is there any sort of chain tensioner on your bike?, what is the chain tension?what is the chain line like?what state is the cog you use in, how worn is it?i would recomend getting a single cog on the rear and some spacers, this will sort a chain line problem.Mozahi No tensioner and it seems to have some give to it so not hard or to wobbly and i dont think that the cog is in a bad shapeThanks for the comments il sort it out first thing tommorow Quote Link to comment Share on other sites More sharing options...
moza Posted January 5, 2007 Report Share Posted January 5, 2007 Ok, well if this doesnt work maybe you could get a singlespeed chain tensioner and a mech saver if you are bothered about boshing it. i made my own, it realy wasnt hard, i will post some pics.Moza Quote Link to comment Share on other sites More sharing options...
gianttrials Posted January 5, 2007 Report Share Posted January 5, 2007 i was running a set up like that recently and i used a shortened brake cable through the back of the mech, and held the mech in line of the gear i wanted, then tightened up the cable, that might be worth a go, but definetly check what everyone else said first (a cut down spoke works just as well as a brake cable by the way), hope this helps mate,ben g Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted January 5, 2007 Author Report Share Posted January 5, 2007 Il try my best trying to fix the problem ... if in cant it looks like il have to take it to halfords.. yes i am THAT bad at fixing bikes lol Quote Link to comment Share on other sites More sharing options...
