Fixed Pants™ Posted January 3, 2007 Report Share Posted January 3, 2007 Mostly in the title...I have a KMC chain (don't know which KMC) and i need to transfer it over to my new ride, i guess i should use the chain tool on the master link? But i don't know which ones which, can anyone tell me what it should look like? Or can i just take any old pin out of any link? Quote Link to comment Share on other sites More sharing options...
Fishy Posted January 3, 2007 Report Share Posted January 3, 2007 Any will do Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 3, 2007 Author Report Share Posted January 3, 2007 Safe, shall sort it now . Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 3, 2007 Author Report Share Posted January 3, 2007 f**k i've got the wrong freewheel for my chain and i can't afford a new freewheel or chain and chain ring SO GAY.Any ideas? Quote Link to comment Share on other sites More sharing options...
Dan Clark Posted January 3, 2007 Report Share Posted January 3, 2007 Don't be a tard next time? Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 3, 2007 Report Share Posted January 3, 2007 While Dan is correct, it's not overly useful at the moment Have you tried running the chain on there, just to see if it does work?Regarding the chain issue, you couldn't use the chain tool on the masterlink even if you wanted to, as the masterlink's pair of pins are fixed in place. Quote Link to comment Share on other sites More sharing options...
Concussion Posted January 3, 2007 Report Share Posted January 3, 2007 OK, I sold Fat Pants a 3/16 ACS Claw when he needed a 1/8 one. :$ (Fookin sizes!)The best I can do is sort him his money back and give him a diamondback dicta 1/8 freewheel (only 1/8 one I've got), so he can ride London this Sunday.What's the deal with 3/16? How much would a new chain and sprocket cost him if he where to stick with the 3/16 one? Does anyone make them?Sos mate! Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 3, 2007 Report Share Posted January 3, 2007 I rode with a 3/16" one when I needed the other size for a while and it appeared to work OK for me. What's going wrong with his? Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 3, 2007 Author Report Share Posted January 3, 2007 Warren (Concussion) is one of the nicest guys i've ever spoken to...And dude, don't worry, it's not your fault, no one knew what the sizes were and thought of it as a problem...Mark - It's not going onto the teeth; it just wraps around the outside of it!*love* Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 3, 2007 Report Share Posted January 3, 2007 Is it a new freewheel with an old chain? Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 3, 2007 Author Report Share Posted January 3, 2007 Yeah... Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 3, 2007 Report Share Posted January 3, 2007 That could well be part of the problem then. With 3/32 or whatever the hell the fraction is freewheels compared to whatever the other ones are, the actual pitch remains the same 1/2", it's just the width of the teeth that vary by a tiny amount. As you've got a larger chain going onto a theoretically thinner set of teeth, there shouldn't be a problem. The only problem you've got is that your chain is no longer 1/2" pitch 'cos it's haggard, whereas the freewheel's still retained it's 1/2" pitch. It's why mechanics recommend changing everything when you change your chain or sprocket or whatever, simply because they all wear each other to the same rate, so they all still fit.So yeah, the reason it won't fit is probably 'cos it's an old chain. Take it to your nearest bike shop, just ask them to try wrapping a new chain around the sprocket and you'll soon see if it'll fit Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 4, 2007 Author Report Share Posted January 4, 2007 While there is a good chance that is true, visually, you can see the difference with ease... Quote Link to comment Share on other sites More sharing options...
Concussion Posted January 4, 2007 Report Share Posted January 4, 2007 Thanks Glen, will post your stuff in the morning! Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2007 Report Share Posted January 4, 2007 To give you an idea, my BMX chain had stretched so that it was an entire link longer. I'd be almost 99% sure that it's purely 'cos you've got an old chain. KMC Kools are notorious for stretching, so it's almost definitely that! Quote Link to comment Share on other sites More sharing options...
Concussion Posted January 4, 2007 Report Share Posted January 4, 2007 I tried it with a random KMC chain and a normal one I had... same results, it was way off! What's all this 3/16" - 1/8" all about anyway? .... I hate fractions.Cool if it does fit with a new chain though! Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2007 Report Share Posted January 4, 2007 It's the width of the teeth. Basically, you can't have an 8spd or a 9spd cassette with a thick singlespeed chain because it'd be a mile wide, and it'd be harder to shift. As a result, they made the teeth narrower so they could put them closer together, and made a narrower chain to suit. With BMX freewheels like the ACS Claw, it was mostly just a racer thing so you could run a smaller, lighter drivetrain.Anyway, the thing is is that the pitch of the chain, the distance between the pins in the chain, is the same whether it's 1/8 or 3/32. Therefore, with a new chain, it SHOULD fit OK, as it's more likely that his chain has stretched. To give you an idea, with the Parktools chain wear tool, if it's more than 0.75% stretched, they think it's OK to just replace the chain, but if it's 1% stretched they reckon it's best to re-do the entire drivetrain. 1% of 1/2" is bugger all, so if it's that far out it's pretty likely that it won't fit over that freewheel.So yeah, like I said, a new chain should do it, but bikes are awkward bastards so it might not Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 4, 2007 Author Report Share Posted January 4, 2007 (edited) I've taken a better look and the teeth are definetly too wide; <--|-->Too wide that way (shit diagram)...Just need a new freewheel then. Edited January 4, 2007 by Fat Pants Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2007 Report Share Posted January 4, 2007 Have you got a 3/32" chain on a 1/8" freewheel or something? Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted January 4, 2007 Report Share Posted January 4, 2007 I've taken a better look and the teeth are definetly too wide; <--|-->Too wide that way (shit diagram)...Just need a new freewheel then.You're probably better off buying a wider chain as it's both cheaper and easier. Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 4, 2007 Author Report Share Posted January 4, 2007 Have you got a 3/32" chain on a 1/8" freewheel or something?I've got a 1/8" chain... Old freewheel is 1/8", new one (and it says on it) 3/32"You're probably better off buying a wider chain as it's both cheaper and easier.= New chainring aswell...Rather poor at the moment... Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2007 Report Share Posted January 4, 2007 Chainrings deform easier than freewheels in my experience, so the chainring would probably wear pretty fast to a new chain. Just piece it together Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 4, 2007 Report Share Posted January 4, 2007 Hang on. What size is your freewheel? Halfway through the thread it changed from a 3/16th to a 3/32th If you haven't noticed.If its a 3/32th it will work fine, I'm running an 8th inch kool on a 3/32th ACS no problem, and a 3/32th chainring.BUT it sounds like your ACS is the megga fat 3/16th size, which means yes, indeed it is the wrong size, and 3/16ths is obviously 1/16th wider than 1/8th. So your chain isn't going to fit. In other words, new chain or freewheel. My LBS has some 3/16th kool chains in stock, so they do exist, there fat as fook. Think orgun_donor is running one, looked like it on Christmas eve. Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 4, 2007 Author Report Share Posted January 4, 2007 Yeah the change between the sizes (3/32 and 3/16) is a confusion, i now know that the frewheel is 3/16". Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 4, 2007 Report Share Posted January 4, 2007 Yeah. It is confusing, in fact that's why my LBS has the 3/16th chain in stock, I asked for some 3/32th's and they ordered the wrong one by accident. But anyway:3/32ths is a standard size, its used for 6-8 speed setups, and racing BMX's.1/8th is standard singlespeed and anything up to 5 speed. (same as 4/32ths) 3/16ths is used on mopeds and as a megga though BMX chain. (same as 6/32ths)You can use a 18th chain on a 3/32th sprocket/freewheel fine, and a 3/16th chain can just about be used on a 1/8th sprocket/freewheel.Obviously a narrower chain will not physically fit on a wider sprocket.9 speed complicates things even more, but as trials riders, none of us give a crap. Quote Link to comment Share on other sites More sharing options...
