Spacers?.
mbuk
Hi there,could you please tell me how many spacers you run on your bike,i have got hope spacers im running two small ones and a medium one,but when they are all on my stem top bolt sits about half a mm above the steerer tube i would say it would be okay but i want someones views,also how far do you put the starnut in the steerer tube is it about 1mm.
there no right or wrong amount of spacers. it really is personal preference, currently running none on my ashton, but was running 12mm of spacers on the bt. personally id have about 5mm of clearance at least (up to about 8mm) between the top of the steerer and the top of the stem(i assume this is what you mean), means you can tighten it all up ok, and there will still be some more left, in case the bearings settle in/compact.
as for the starnut, i put mine in just under an inch, basically so that when u put the stem + spacers on, and then ur top cap, youl get 4 or 5 turns of the bolt before you start putting preload ont he bearings.
On some headsets such as the hope you have a little piece of the headset you put on top of the cup itself, I shall try to find a pic, if you remove this, place the stem on top and then mark where the top of the stem is on the steerer tube, cut it to that level and then place the whole headset back together, should be the perfect height.
On headsets without this such as my Echo, aim for between 3-5 mm, if its flush or too close to the top it will give you headset rock and your bike will ride pretty nasty.
Headset spacers are good to use so long as you dont use too many as I believe it can add extra stress the to the headtube due to the extra leverage available above the headset, dont quote me on that though.
it needs enough space above the steerer tube to pull up and be tight, probably 3mm - 5mm should be okay, as for the star nut go to your local bike shop an ask to borrow there tool. it should then fit at the right distance and be straight aswell. better still fit a headlock they're much better and safer/secure,
good luck, hope this helps,
ben g
