dan the trials man Posted January 3, 2007 Report Share Posted January 3, 2007 Hi allI was just wondering what gearing you would all recommend on my zoo pitbull for street. I know it comes up all the time but there was nothing precise in the search, i have a 22 on the front and a 17 on the back i run a hope xc but i was thinking about changing to a fixed hub with a freewheel. The best freewheels were all in 18t can some one help?ThanksDan Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 3, 2007 Report Share Posted January 3, 2007 The gearing you're currently running is pretty hard. A lot of people run 22:18, this would probably solve your chain tension worries in the other thread too. I've always thought that the most commonly preferred gear ratio in trials works out as 30 gear inch, This is a measurement of gearing taking into account the wheel size. The ratios in yellow are all the ones around 30 gear inch. There's quite a few options. But depending on what you like there are loads of options of what you could run nearish to 30. The front sprocket size is up the left and the rear along the top. Quote Link to comment Share on other sites More sharing options...
ben_travis Posted January 3, 2007 Report Share Posted January 3, 2007 see you have done it the complicated way IMO. but cheers anywaywhen i calculate it i normally divide the front cog by the rear cog. then higher the number = stiffer......suppose your way is correct when your wondering which gear is best for each bike size etc etc, where as mine is better for finding how much stiffer a gear will be.meh Quote Link to comment Share on other sites More sharing options...
max-t Posted January 3, 2007 Report Share Posted January 3, 2007 Hahahaha 16 - 16 for me at the moment. I really hate it but i have no choice. Quote Link to comment Share on other sites More sharing options...
dan the trials man Posted January 3, 2007 Author Report Share Posted January 3, 2007 I cant change to 18 yet because i have not got the money, what do you all think about changing to a freewheel though. Quote Link to comment Share on other sites More sharing options...
GTF Posted January 3, 2007 Report Share Posted January 3, 2007 So a 22/17 on a 24" will be ligther than 18/15 on a stock? Quote Link to comment Share on other sites More sharing options...
bikerider Posted January 3, 2007 Report Share Posted January 3, 2007 First started with 22/18, then 22/17now changed bikes and gone front freewheel, used 18/16 at first as recommended, but found it too easy. Use 18/15 now Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 3, 2007 Report Share Posted January 3, 2007 see you have done it the complicated way IMO. but cheers anywaywhen i calculate it i normally divide the front cog by the rear cog. then higher the number = stiffer......suppose your way is correct when your wondering which gear is best for each bike size etc etc, where as mine is better for finding how much stiffer a gear will be.mehYeah, I ride 24", so to compare stuff to other peoples bikes its easier to do the gear inch calculation. Quote Link to comment Share on other sites More sharing options...
Nick Garland Posted January 3, 2007 Report Share Posted January 3, 2007 Ive had a variety of ratios over the years22-2022-1922-1822-1722-16 (yes I know hard, was an accident and didnt realise)20-1720-1616-1316-1417-14I have to say out of the lot my favourites would be22-1820-17 (possibly the nicest)16-1417-14They are all pretty similar, I am on 17-14 at the moment, its abit harder than 16-14 but abit lighter than 22-18. Its between 22-18 and 20-17, good for taps as speed can be built, also good for techy stuff as its not too hard that its a mission to use, yet its not too light for rolling gaps etc. Quote Link to comment Share on other sites More sharing options...
Phil H Posted January 3, 2007 Report Share Posted January 3, 2007 22 - 18 pure heaven!!!!Phil Quote Link to comment Share on other sites More sharing options...
future orange 660 Posted January 3, 2007 Report Share Posted January 3, 2007 16 13 Quote Link to comment Share on other sites More sharing options...
petit_pablo Posted January 3, 2007 Report Share Posted January 3, 2007 Im on 20-16, by far the best gear ratio i have ridden in so far Quote Link to comment Share on other sites More sharing options...
robonatomz Posted January 3, 2007 Report Share Posted January 3, 2007 on my 26" 18-14and on my 20" at the mo 18-12 but i want a 20 tooth freewheel or eleven rear cog if any one has either! please for the love of god the gearing on that bike needs to be harder!rob Quote Link to comment Share on other sites More sharing options...
Phil H Posted January 3, 2007 Report Share Posted January 3, 2007 A couple of my mates ride in 22 - 16. Stupidest thing ever! So high!Phil Quote Link to comment Share on other sites More sharing options...
Christophe' Posted January 3, 2007 Report Share Posted January 3, 2007 20 15 on 24. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 3, 2007 Report Share Posted January 3, 2007 18:17 - perfect18:18 - very good18:16 - bad22:18 - very bad18:17 any time Quote Link to comment Share on other sites More sharing options...
Concussion Posted January 4, 2007 Report Share Posted January 4, 2007 This thread is confuzin! Quote Link to comment Share on other sites More sharing options...
robonatomz Posted January 4, 2007 Report Share Posted January 4, 2007 18:17 that must feel like your chain has come off i used to use 18:13 but have moved to 18:14 cuz i wanted an easy gear! lolrob Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted January 4, 2007 Report Share Posted January 4, 2007 Im running 18:16But 18:18 felt really nice on Gavin Badfords ashton..... Quote Link to comment Share on other sites More sharing options...
GTF Posted January 4, 2007 Report Share Posted January 4, 2007 I had 18:13, but that was too hard, so I changed to 18:15 and that is perfecto! Quote Link to comment Share on other sites More sharing options...
max-t Posted January 4, 2007 Report Share Posted January 4, 2007 Im running 18:16But 18:18 felt really nice on Gavin Badfords Bedfords ashton.....I disagree with you there, really horrible for street, but apparently benefits for natural according to the man himself. But meh, seems too light. Quote Link to comment Share on other sites More sharing options...
Billy Posted January 4, 2007 Report Share Posted January 4, 2007 I run 22-26 Quote Link to comment Share on other sites More sharing options...
craigjames Posted January 4, 2007 Report Share Posted January 4, 2007 i run 22-17, been told by a few peoepl its a bit heavy but seems to suit me ok, i mean would i actually notice any benefit to running 22-18?craig Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted January 4, 2007 Report Share Posted January 4, 2007 i ride stock and im currently running 18:16 as i have a front freewheel, before i've run 15:13 ,15:12 ,20:17 and 20:16.i think im going to try 18:15 soon and see how it goes .steve Quote Link to comment Share on other sites More sharing options...
Broomer Posted January 4, 2007 Report Share Posted January 4, 2007 22-18 might try 22-17 sometime though. Quote Link to comment Share on other sites More sharing options...
