I-LUV-TRIALS Posted January 2, 2007 Report Share Posted January 2, 2007 hi,i have just brought some new pads- 1 koxx blue and 1 rock pad blueand have re-grinded my rim(harsh) but my brake has no hold or bite????please help its really annoying Quote Link to comment Share on other sites More sharing options...
c.kezer Posted January 2, 2007 Report Share Posted January 2, 2007 it could be that your pads havent beded in yet give them some time.also why have you bought 1 of each pad?chris Quote Link to comment Share on other sites More sharing options...
Ghetto Rider Posted January 2, 2007 Report Share Posted January 2, 2007 have you bought one of each pad?If so why? If not then put the koxx on and set-up the brake! Then just ride around with the brake on and hopefully over time you'll get a squeak. Keep doing it untill it sounds like a pig being killed and you cant pedel anymore and hey presto!!! Dan Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted January 2, 2007 Report Share Posted January 2, 2007 Rock Pads will take a while to bed in and will have decent hold hold etc. But I think the Koxx Blues are a bit soft and will just be torn apart by a harsh grind and won't grip much in the short amount of time they last anyway Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted January 3, 2007 Author Report Share Posted January 3, 2007 i am running two different pads because the koxx works well in the wet and the rock pad work well in the dry therefore good braking all round give it ago its amazing Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 3, 2007 Report Share Posted January 3, 2007 I-LUV-TRIALS said: but my brake has no hold or bite???? I-LUV-TRIALS said: i am running two different pads because the koxx works well in the wet and the rock pad work well in the dry therefore good braking all round give it ago its amazinghow can it be amazing if its got no hold or bite? anyway, running different pads is fine, bit annoying if they wear at different rates thoughdo you run a booster? that may help a tad Quote Link to comment Share on other sites More sharing options...
flas12345 Posted January 3, 2007 Report Share Posted January 3, 2007 hiit may be that your pads have just not beded in yet or it could also be that your brakes need bleedinghope i have helped Quote Link to comment Share on other sites More sharing options...
matt! Posted January 3, 2007 Report Share Posted January 3, 2007 (edited) ride about with brake on abit to bed your pads in, and set your brake correctly and your brake should your fine, also spin our back wheel and put hot kettle water on it and then dry the water of with a rag/cloth..the hot water will get ride of dirt on your rim and help your brake preform better..hope it helps.. Edited January 3, 2007 by matt! Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted January 3, 2007 Report Share Posted January 3, 2007 I-LUV-TRIALS said: i am running two different pads because the koxx works well in the wet and the rock pad work well in the dry therefore good braking all round give it ago its amazinghaha, everyone thinks rock pads blues are only good in the dry, and i really dont know why!! but it pisses me off...Blue rock pads piss on ANY OTHER PADS ON THE MARKET!!! They amazing in the dry, and still, very amazing in the wet, they dont loose ANY performance.. they even still sqeek in the wet... in a fooking MASSIVE dirty puddle... lolP.S, never have a harsh grind, it defeats the object of having a grind, light, sharp is the way forward... Quote Link to comment Share on other sites More sharing options...
ZOO! 2007 Posted January 3, 2007 Report Share Posted January 3, 2007 to make them bed in a bit quicker then get some wet and dry paper and slowly roughen it up then they bed in quicker than riding them! Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted January 3, 2007 Report Share Posted January 3, 2007 oooorock blue pads seem to be very good i seegood job i ordered some rock pads then before i read this.JK Quote Link to comment Share on other sites More sharing options...
Alastair Posted January 3, 2007 Report Share Posted January 3, 2007 How old is your brake? Because you may need to bleed it again? Check that the pads are both moving, or as lame as it sounds check the positioning of your pads in relation to the rim, and if your fluid is old then they wont pull or return that well.Al Quote Link to comment Share on other sites More sharing options...
trials wannabe Posted January 3, 2007 Report Share Posted January 3, 2007 just wondering if someone hasnt asked this before ( is it a maggy ? and if so is it fully bled Quote Link to comment Share on other sites More sharing options...
Razzy Posted January 4, 2007 Report Share Posted January 4, 2007 Hi, I put my new Rock Pad Blues in yesterday and went down to ride about in a car park near mine.About 5 minutes after i got there, it started pissing it down and my brakes were absolutely awesome! I only had a light grind on my rim but the brakes were working excellently and completely locking aswell as sounding great!So basically i didnt have to wait at all for my brakes to bed in, although my rim had just been ground and so was quite clean. Maybe your rim has a bit of oil or dirt on? Quote Link to comment Share on other sites More sharing options...
chasthetrialsrider Posted January 4, 2007 Report Share Posted January 4, 2007 yeh check for oil i put some on my brakes once to help them move ( i know what the hell did I do that for) but it stopped my brake gripping for about a week put some really hot water on them then go ride pulling the brake really hard will help to bead them in also if this doesnt work go and ride around in a puddle i have a maggy red on the front of mine with an unground rim at it made it stick like glue it was great it also made my back brake work better aswell that has a light grind with plazmatic pads on it (they are super great pads) also it isnt a new brake you have put them on is it because i have known loads of people that have bought new brakes and when they get them they have no fluid in them and they put them on go to ride and the y dont work I just carnt help but rack up laughing when they tell me hahahahahope ive helped m8 Quote Link to comment Share on other sites More sharing options...
Tylerlovesalex Posted January 4, 2007 Report Share Posted January 4, 2007 Alastair said: How old is your brake? Because you may need to bleed it again? Check that the pads are both moving, or as lame as it sounds check the positioning of your pads in relation to the rim, and if your fluid is old then they wont pull or return that well.Alnah mate i have a water bleed on a new 04 lever and 06 slaves, i fixed it by regrinding my rim and now its mint didn't slip at all today even in the rain Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted January 4, 2007 Author Report Share Posted January 4, 2007 Xx-OnZa-xX said: nah mate i have a water bleed on a new 04 lever and 06 slaves, i fixed it by regrinding my rim and now its mint didn't slip at all today even in the rain sorry about confusing you all forgot it was on my mates account, lol Quote Link to comment Share on other sites More sharing options...
JohnyMilton Posted January 4, 2007 Report Share Posted January 4, 2007 hey mate, ithink its cause your not using a V, there mint, lol its probaly not working becasue ur pads and broke in yet, or your rim needs a clean.thats happened to me a couple of times!!!Johny Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted January 4, 2007 Author Report Share Posted January 4, 2007 ive said i sorted it by re-grinding my rim Quote Link to comment Share on other sites More sharing options...
rossmonty221pr Posted January 5, 2007 Report Share Posted January 5, 2007 have you bled the brake? Quote Link to comment Share on other sites More sharing options...
