531joshua Posted January 1, 2007 Report Share Posted January 1, 2007 AlrightI've noticed some topics with guides in how to go about bleeding Magura hs33 brakes.Although i'm more experienced with disk brakes, i had a thought on the 'bleeding hs33's with water subject'.As some of the inside of the magura hs33 brake is metal will this not be prone to rot/rust due to the water?If it was good to use water then why do the professional majority use specific oil?I did think maybe a lot of the brake is aluminium so it will be quite resistant to rust?Please comment as i'm needing to give my brake a bleed and would like to make a good job.Thanks, Josh. Quote Link to comment Share on other sites More sharing options...
Si-man Posted January 1, 2007 Report Share Posted January 1, 2007 Made of aluminium, not much is going to happen to tell the truth, plus, its a closed systemOnly thing that tends to die are the seals, they tend to split.Just stick to what is supposed to be in there, then you will be fine. Quote Link to comment Share on other sites More sharing options...
531joshua Posted January 1, 2007 Author Report Share Posted January 1, 2007 New -Just heard that the water will evapourate too...then it will get dirty etcSticking to oil Thanks... Quote Link to comment Share on other sites More sharing options...
trials 123 Posted January 2, 2007 Report Share Posted January 2, 2007 hii have alway used water in my brake and i have never had one problem with it and when i have had oil in my brake in the past it tends to fell soft and spongy but with water it doesn't i hope i have help with your question thanks SAM Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 2, 2007 Report Share Posted January 2, 2007 (edited) Water can't evaporate inside a closed system! If it did it wouldn't make a difference anyway as the vapour would have no where to go to, it would just condence and cool thus turning it back into its liquid form. Edited January 2, 2007 by Fat Pants Quote Link to comment Share on other sites More sharing options...
