Saracen Mad 2.zero And A Bashplate
Drew92
Hi, Im new to trials and my first bike is a mod Saracen mad 2.zero. It already has a bashring on but i want a bashplate. Will any bashplate fit my bike or will only some fit. Also if any one has any recomendations on which one to get that would be great.
Thanks,
Drew92
bump (sorry if this is not allowed)
Bumping isn't allowed, but it's more the case that bumping 20mins or so after a post is a bit pointless...
As far as I can remember, you can't fit a bashplate on a 2.Zero without adding mounts to the frame which would weaken it quite a lot. Just stick with a bashring and try not to rely on it too much and you'll be fine :)
Well perhaps he wants a bash plate just in case he trys a move and accidently hits the frame.
I don't use my bashplate intentionally but it has saved my frame a times.
I imagine you could get a scrap bit of metal, curve it to the shape of your frame, and attach it with a few zip ties. Not forgetting the shock absorber to go in between it and the frame.
