How To Hook-up
will_zooboy!
SPEED WEIGHT FORWARD HOOK!!
that putting it simply
Start on somthing sloped if you can, it makes it sooooo much easier! Start a few bikes lengths away, do a full rotation to get the speed and as you are getting closer, do another full rotation and lift off with your bad foot (like a tap) and jump the bike up, you want to get the front wheel comfortably on top of the objest with as much weight forwards as possible, the more weight forward the easier it is to get the rest of the bike up, also the faster you do it the mor forwards momentum you will have to carry you on to the top.
If you are wanting to hook a vertical wall you need the wall to be higher than your bikes lenghth otherwise you wont be able to hook. I find it much easier to hook higher walls than small walls, unlike Damon who can hook anything going!!!
Like Ali said try it on a sloped wall, like the one in Bradford, everyone knows about that beautiful wall!!!
lewis
well explained ali, that could help alot of peeps out there (Y)
lisen to ali c...
lewis
back of the uni, fun place to ride. specially when you build a big ramp and backwheel walls like 7foot high haha.
