Booster Problem
The lemonade man
So, my dad got me a booster as one of my xmas things, except tarty didn't have the one I wanted in stock so they sent a different one (echo control 4 bolt). Put it on my bike, mod, and found it doesn't fit. I looked it up and it says that it's for use with stocks only.
Basically the tyre rubs on it but would only need to be moved about half a cm backwards. Problem is the chains too tight and there isn't enough room to put in another link.
Any easy way to get around this or should I just send it back and try to get a replacement?
