Help Needed With Maggy Lever
Josh PWND
Hi i need some help my maggy lever only pulls in a certain length and stops dead and i can not pull it any further so could someone please help me mend it or would it be easier to buy a new one (rb design). were can you buy rb from..
Thanks Josh
Did you use the TPA to set up the brake by any chance?
Sounds like the slave pistons can't get out any further. That causes the lever to stop at a certain point before it reaches the bars.
Undo the tpa all the way and set up the slave pistons again! If that doesn't help, bleed the brake.
