Ryan Blackwell Posted December 24, 2006 Report Share Posted December 24, 2006 (edited) Hi there.This may sound a silly question but whats the difference between having a freewheel on your crank or a freewheel on your hub.Cheers for any help . Edited December 24, 2006 by baseboy Quote Link to comment Share on other sites More sharing options...
joewhite Posted December 24, 2006 Report Share Posted December 24, 2006 umm on the rear you have to run a chainring on your cranks (anything between 22t and 24t) and on the front you run a rear chainring (12t) also i think im right in saying a rear freewheel would last longer than a front as there's less stress on the freewheel, but some frames wont allow a rear free to be used (zona's, zoo!s. i think montys and frames like that will allow the use of rear free) as the chainline causes the chain to rub away at the frame.I believe a rear free would increase the ep's? might be wrong but its that or they feel stronger. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 25, 2006 Report Share Posted December 25, 2006 but some frames wont allow a rear free to be used (zona's, zoo!my mate ran 22/24 - 18/16 on his python without any rubbing problems. Rear freewheel will give a faster engagement than front because your moving the chain faster (because of the larger chainring) whereas on ffw your pedaling straight into the engagement (if that makes sence ) and it takes alot of stress off of your freewheel . Quote Link to comment Share on other sites More sharing options...
CJtrials Posted December 26, 2006 Report Share Posted December 26, 2006 The only reason I run a front 18 tooth freewheel and a 12 tooth rear sprocket is to make the gear harder.. Cheers CJ.. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 26, 2006 Report Share Posted December 26, 2006 The only reason I run a front 18 tooth freewheel and a 12 tooth rear sprocket is to make the gear harder.. Cheers CJ.. Harder than what?Everyone I know that ride's mod uses 18-12.The differance to me between a FF set-up and a freehub set-up is about £50 or so, maybe even more, onzaboymark totted up the prices once and FF was considerably cheaper for comparable performance. Quote Link to comment Share on other sites More sharing options...
