Help Maggie
Conor the basher.
I personally don't have a Marta, but mostly all hydro brake are the same... under the lever blade, there should be a rod that links to the master cylinder, there should be a small hex slot where that rod links with the lever blade... A picture would be better
IPB Image
The red thingy I marked, there should be some thing similar on your lever, chances are it won't be as exposed as on the El Camino I used to demonstrate...
