Bigman Posted December 24, 2006 Report Share Posted December 24, 2006 Some recent pics of my simtra with new home made adapters and booster (made with an angle grinder )My new home made spring steel tensioner, no more broken hangers [attachmentid=8963][attachmentid=8964]For some reason the rest of the picutres have not come out very well, so these are the only ones for the minute Spec:Simtra ST1 frameBT F6 forksOnza 30inch alu barsEcho 115mm x 10deg stemFSA heatsetFront Hope XC built to a DX32 with 25mm holes sprayed white.Rear CK Discotech built to a white koxx rimHighroller ST tyres front and rearMiddleburn RS7 cranks with home milled and drilled bashFSA bottom bracketGusset slim jim pedalsRear dewhore brake with joypads, linear slick cable and SD7 lever, home made adapters and boosterFront 203mm BB7 with SD7 lever and random cable.Hope you likeAdam Quote Link to comment Share on other sites More sharing options...
Tom_ Posted December 24, 2006 Report Share Posted December 24, 2006 Loves it! Made the adaptors with an angle grinder looks like a pretty good job to me. Quote Link to comment Share on other sites More sharing options...
Conor the basher. Posted December 24, 2006 Report Share Posted December 24, 2006 That looks mint, max said them brakes a amazing i should have come to malver.Nice one. Quote Link to comment Share on other sites More sharing options...
max-t Posted December 24, 2006 Report Share Posted December 24, 2006 Love it adam! Whe you coming to the midlands again? Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 25, 2006 Author Report Share Posted December 25, 2006 I will be back up on the 6th of january Adam Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted December 25, 2006 Report Share Posted December 25, 2006 really nice those frames like it. now christmas is over ill have to get one of those rolhoffs for my birthday.sweeeeeeeeeet Quote Link to comment Share on other sites More sharing options...
mixmaker Posted December 25, 2006 Report Share Posted December 25, 2006 all is ok, but rims...rims is not good... Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 25, 2006 Author Report Share Posted December 25, 2006 all is ok, but rims...rims is not good...Whats wrong with the rims??Adam Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 26, 2006 Author Report Share Posted December 26, 2006 Pics of my new home made tensioner added.....Adam Quote Link to comment Share on other sites More sharing options...
ian Posted December 26, 2006 Report Share Posted December 26, 2006 adam how on earth does that tension work?and when is that avid bb7 going on the back? Quote Link to comment Share on other sites More sharing options...
TheMunn Posted December 26, 2006 Report Share Posted December 26, 2006 Why would you bother making that over using a rolhoff tensioner? Are you ill? Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 26, 2006 Author Report Share Posted December 26, 2006 Why would you bother making that over using a rolhoff tensioner? Are you ill?Thing is, even with a rolhoff it is possible to snap hangers! I am going to give this a try over the next few days and see how it goes.....Oh, and Ian, i don't know when i will be putting a BB7 on the back, i sold the one i was going to use Adam Quote Link to comment Share on other sites More sharing options...
ian Posted December 26, 2006 Report Share Posted December 26, 2006 Oh, and Ian, i don't know when i will be putting a BB7 on the back, i sold the one i was going to use Adami would slap you if you were within reach loland how does that tensioner work anyhow? Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 26, 2006 Report Share Posted December 26, 2006 spring steel by the looks of it. thin sheet steel and works like a leaf spring. great idea actually i may knock one together and see if it works well Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 26, 2006 Author Report Share Posted December 26, 2006 Right, the tensioner works by having a bit of plate bent into an L shape, one end has a hole big enough for the funbolt to fit through, this end is then clamped between the frame and the axle, the other end which is at 90degrees to the bit which is clamped has a sloted hole allowing adjustment for the spring steel, the spring steel is then bolted to the slot so that it point down, becuase it is spring steel it will always (few exceptions) return to its original shape, so it is then bent up and placed above the chain, hence pushing down.........It is had to explain.Adam Quote Link to comment Share on other sites More sharing options...
TheMunn Posted December 26, 2006 Report Share Posted December 26, 2006 Did you not think about getting a hanger banger or something ? That would stop you snapping mech hangers. Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 26, 2006 Author Report Share Posted December 26, 2006 Did you not think about getting a hanger banger or something ? That would stop you snapping mech hangers.They do not with with Ck funbolts, this has not cost me anything to make, so it does not bother me if it turns out to be no good, and i have the rolhoff so i can put that straight back on Adam Quote Link to comment Share on other sites More sharing options...
_skj0lsvik_ Posted December 26, 2006 Report Share Posted December 26, 2006 Same sort of tensioner that Felix Mücke is using Your bike looks good. Quote Link to comment Share on other sites More sharing options...
26inch Posted December 26, 2006 Report Share Posted December 26, 2006 Not too sure about the tensioner. Why dont you use a fixed tensioner attached to the fun bolt, thats what i run and it never comes loose and doesnt rely on mech hangers Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 26, 2006 Author Report Share Posted December 26, 2006 Not too sure about the tensioner. Why dont you use a fixed tensioner attached to the fun bolt, thats what i run and it never comes loose and doesnt rely on mech hangersI don't like fixed tensiners, as you get tightspots in the drivetrain when using them, as if you watch a chain running through a mech or sprung tensioner it always tensioner always goes up and down, which is what would make the tight spots.Adam Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 26, 2006 Report Share Posted December 26, 2006 love the tensioner!! its inspired me to make my own! Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted December 26, 2006 Report Share Posted December 26, 2006 let us know how the tensioner goes like in a few days or so, im tempted to do the same. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 26, 2006 Report Share Posted December 26, 2006 Trials Forum Trends#42923...Nice work, be interesting to see how it works out Quote Link to comment Share on other sites More sharing options...
