Is It Possible To Run A Hs33 Caliper With A Hope Lever?
joetrials06
Basically i run a hs33 and i love it when it works but i spend all my time replacing the tpa's and i don't like the way you have to bleed them. So i was wondering if you can run a hs33 caliper with a hope lever. If anybody has already done this a pic would be great.
Nah, its simple enough. Hope C2 lever, Maggie caliper, Hope hose with maggie fittings one end, and hope fittings the other. Bleed with water. Done, you have one spongy pain in the arse to set up break.
Just get a Deng lever and metal TPA wheel on an 05 lever, or a fresh products lever on 04, then the TPA shouldn't break.
