Greetings Posted December 22, 2006 Report Share Posted December 22, 2006 Alright people. I've been investigating the eagle claw bashring recently and have a few questions about it. First of all, this bashring slides onto the bb right? That means that you can't screw the cranks down hard enough and that will result in the taper getting damaged. Or do the Monty cranks have a tighter taper to stop this happening?Secondly, will the bashrings accommodate a KHE Collapse chain on a standard 18T screw on sprocket?And 3rd of all, the Monty cranks seem almost identical to the Tensiles. Does that mean the durability will be similar? Are they also made of 7005 aluminum? Really need a bashring with more grip and the Monty is the only one I can think of.Merry Christmas. Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 22, 2006 Report Share Posted December 22, 2006 the monty bash comes in two pieces. one mounts on the crank the over on the bb, and yeh they monty cranks are identical to tensiles. dont get them, make your own bash, isnt that hard and you can make it as grippy as you want. Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 23, 2006 Author Report Share Posted December 23, 2006 Cheers, anyone else? Quote Link to comment Share on other sites More sharing options...
dave85 Posted December 23, 2006 Report Share Posted December 23, 2006 On mine the crank has metal taken off the back edge to allow for the thickness of the extra bash. You simply couldnt get the crank all the way to the stop on the bb because of that, so it isnt damaging anything. Quote Link to comment Share on other sites More sharing options...
