Spokes
lawrence osborn
hey guys,
i have just built my new echo back mod wheel, i have tightend all the spokes to the same tension and 8/10 seem to long is there any way i can fix this problem or are they just to long, i used the spokes off of the 2005 t pro back wheel and built it on to the echo 06 back wheel if that helps? so have i just built it wrong or are they to long?
cheers lawrence
any pics just ask (Y)
hey guys,
cheers lawrence
Is it every 4th spoke that's too long?
If so, its laced incorrectly... plus, as others have said, you will ideally need different length spokes for the new rim (approx 3mm in this case)
Cheers
Adam
If most of them are a bit too long and it's not a case of improper lacing, you could always file down the tops of the spokes (from the outside of the wheel). It's not exactly the ideal situation as it could be argued that you will have less thread contact between the nipples and the spokes, but if the spokes are only slightly too long it's probably worth not having to buy new spokes over.
Cheers
Adam
I do this fairly often :P is pretty easy to sort out though.
Cheers
Adam
Was laced wrong to but it was me first attemp at building it but atleast it is right now :P
Edited by lawrence osborn
