Ben Beckett Posted December 17, 2006 Report Share Posted December 17, 2006 here are links to the google vids;the original with sound,http://video.google.co.uk/videoplay?docid=-55518075321438229the edited version (slowed down, repeats a few times. etc)http://video.google.co.uk/videoplay?docid=...181904432080357i have only just started to try and tap those boxes since saturday,(this is my second attempts at it)any tips and advise on how to get the extra height would be highly appretiated thankyou. Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted December 17, 2006 Report Share Posted December 17, 2006 your doing every thing right as ar as i can tell so really the only thing to do is give it some beans Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted December 17, 2006 Report Share Posted December 17, 2006 i have a similar problem with a marina wall even when i hit it and it feels good i still get no where near it Quote Link to comment Share on other sites More sharing options...
Janson Posted December 17, 2006 Report Share Posted December 17, 2006 go practise on smaller stuff. and stuff of same height but with more wall behind, so it's less scary. Quote Link to comment Share on other sites More sharing options...
Ducko Posted December 17, 2006 Report Share Posted December 17, 2006 find a smaller wall and keep working on the move until you can get the height then go back. its all about practice and time im affraid! Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 17, 2006 Report Share Posted December 17, 2006 pedal right until you actually tap, then jump, lean into it more, like more over the bars but stay low, hit the wall then jump. maybe go faster Quote Link to comment Share on other sites More sharing options...
BAZZA Posted December 17, 2006 Report Share Posted December 17, 2006 chrishayton said: pedal right until you actually tap, then jump, lean into it more, like more over the bars but stay low, hit the wall then jump. maybe go fasterget more weight forwards and like chris says 'lean into it'. i normall practice on a wall the same size or bigger, so the technique is in my head then go at the object i am wanting to do.seems to work i find when i am doing wall taps i can do them alot higher than onto railings or thin objects. its all in the head, mind over matter.chris Quote Link to comment Share on other sites More sharing options...
Ben Beckett Posted December 17, 2006 Author Report Share Posted December 17, 2006 cheers for the snappy replies guys, i don't/havent found tryin the tap on that box scary............it just feels like any other wall that is big/fat/thin.i will most likely have another go at it tonight, so after a few days at giving it a go i will be more use to the height and may do it! Quote lean into it more Quote go faster^i'll give that a go. ^and that.more replies still appretiated Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 17, 2006 Report Share Posted December 17, 2006 instead of a left right pedal, do a full stroke....start good foot forward and end good foot forward, it really helps.More speed will help and a bigger jump and keep the weight forwards slightly. Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted December 17, 2006 Report Share Posted December 17, 2006 Go quicker.If that still doesnt work maybe try hitting it lower. Quote Link to comment Share on other sites More sharing options...
skuzzbucket Posted December 17, 2006 Report Share Posted December 17, 2006 try it a bit faster and get more explosive in the jump orfind something of same height with a bit more grip on, (metal slippy)til you got it nail then go back. Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 17, 2006 Report Share Posted December 17, 2006 You're clearly not getting enough height. Technique is fine, you need to put more power into the jump itself. Ali C said: instead of a left right pedal, do a full stroke....start good foot forward and end good foot forward, it really helps Or 2 full rotations - constant pedaling from start to finish. Makes a huge difference Quote Link to comment Share on other sites More sharing options...
GTF Posted December 17, 2006 Report Share Posted December 17, 2006 (edited) Correct me if im wrong, but you only did a half pedal rotation?Try to do a whole pedal rotation. Youll get much more power in the move EDIT: Just saw Ali C's post. Hehe. Do like he says Edited December 17, 2006 by GTF Quote Link to comment Share on other sites More sharing options...
Davetrials Posted December 17, 2006 Report Share Posted December 17, 2006 (edited) Not tapping low enough? Edited December 17, 2006 by Davetrials Quote Link to comment Share on other sites More sharing options...
max-t Posted December 19, 2006 Report Share Posted December 19, 2006 practice makes perfect better. Hit it lower if its really high and deffinately go faster. Quote Link to comment Share on other sites More sharing options...
Damon W Posted December 19, 2006 Report Share Posted December 19, 2006 (edited) go ALOT faster, like hook speed and smakk front wheel in lower with your weight slightly more forward, this increases the rebound off front end Edited December 19, 2006 by Damon W Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 19, 2006 Report Share Posted December 19, 2006 Get the height before bringing it out into the open, you'll f**k that box big time.Practise in 'private' on some pallets.(P.s just watched your video on Google under the tap one, have you just learnt to tap? that has no taps in it.You also love putting your name in at every given opportunity!) Quote Link to comment Share on other sites More sharing options...
TrashZen Posted December 19, 2006 Report Share Posted December 19, 2006 N.Wood said: Get the height before bringing it out into the open, you'll f**k that box big time.Practise in 'private' on some pallets.Yeah, that'll stop passers by to complain if you get it right first time.else, it looks like you are hitting it too soft and jumping too early (not getting the full boost of the tap), but you're nearly there. Once you'll get it right, it'll just be a mental game. Quote Link to comment Share on other sites More sharing options...
SubZero Posted December 19, 2006 Report Share Posted December 19, 2006 you guys are all wrong! Go a bit faster and tap with more power these are the points where i agree and at alic's comment to!BUT....i guess it would be easier if you have already left the ground when you tap!So jump/tap and then you will be ON the Box. In this way your back tyre will lift itself up on it!I am training this technic for a short period of time now but it works. Quote Link to comment Share on other sites More sharing options...
Janson Posted December 19, 2006 Report Share Posted December 19, 2006 Yeah I'm sure Damon has got his tap technique all wrong... Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 19, 2006 Report Share Posted December 19, 2006 SubZero said: you guys are all wrong! Go a bit faster and tap with more power these are the points where i agree and at alic's comment to!BUT....i guess it would be easier if you have already left the ground when you tap!So jump/tap and then you will be ON the Box. In this way your back tyre will lift itself up on it!I am training this technic for a short period of time now but it works.well you might guess but your wrong, to get big taps your front wheel must tap before you make the jump, trust me thats how you do it Quote Link to comment Share on other sites More sharing options...
SubZero Posted December 19, 2006 Report Share Posted December 19, 2006 well i tap about 46" with this technic....it's not huge but enough....and i learned it by Vincent Hermance...so....! But i guess both technics will work! Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted December 20, 2006 Report Share Posted December 20, 2006 have ye got a video of that technique? sounds werd...adam Quote Link to comment Share on other sites More sharing options...
matt rushton Posted December 20, 2006 Report Share Posted December 20, 2006 (edited) Just go faster. You look like you have everything else sorted.Matt Rushton Edited December 20, 2006 by matt rushton Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 20, 2006 Report Share Posted December 20, 2006 SubZero said: well i tap about 46" with this technic....it's not huge but enough....and i learned it by Vincent Hermance...so....! But i guess both technics will work! vincents weird though, but that techinque will work on natural but getting up big metal boxes etc is not as good. watch the andrew vincent 2 video and you will see he taps then jumps, the coustelliers are perfect to watch how to tap. their technique is perfect. Quote Link to comment Share on other sites More sharing options...
