teeth Posted December 16, 2006 Report Share Posted December 16, 2006 hi just wanted to know everybody opinion on the best mob bike under £500 with maggies cheers TEETH Quote Link to comment Share on other sites More sharing options...
TOBY E Posted December 16, 2006 Report Share Posted December 16, 2006 if your whanting a 20 inch try the new onza t-comp looks a good spec for 450 same frame as 06 t pro with tensile freewheel mounts and pads new onza cranks and new forks(same as 06 but with a disk mount)its also got a nice paint job Quote Link to comment Share on other sites More sharing options...
dan the trials man Posted December 16, 2006 Report Share Posted December 16, 2006 There is a zoo python on e-bay its a bargain check it out.DanJust type zoo then go to sporting goods i think ther is only one on there. Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted December 16, 2006 Report Share Posted December 16, 2006 Personally i would say the zona zip from supercycles, there really nice frames and feal great on the back wheel, p.s. there also a bargin Quote Link to comment Share on other sites More sharing options...
JT! Posted December 16, 2006 Report Share Posted December 16, 2006 New t-comp seems a bargin to me. Quote Link to comment Share on other sites More sharing options...
531joshua Posted December 17, 2006 Report Share Posted December 17, 2006 New t-comp seems a bargin to me. I agree; it seems you get a lot for your money.Josh. Quote Link to comment Share on other sites More sharing options...
Muel Posted December 17, 2006 Report Share Posted December 17, 2006 I would definately go for the T-COMP, if I didn't already have a T-PRO with a Tensile Freewheel.The next upgrade for me is a Zona Zip or Echo Team frame, (Probably Zona!). There isn't actually much difference between the two frames, the zona is just lighter and has slightly different geometry, but I would ring supercycles and get them to upgrade a T-COMP to a Zona Zip frame, I wouldn't buy one of the pre-built Zonas they have, the forks are disgusting...http://supercycles.co.uk/site_details.asp?ProductID=696Or alternatively, get them to upgrade a T-MAG, the frames of them are shite, but the components are the same as the T-COMP, but it comes with a front disc and a sealed front hub, but an ACS claw freewheel, which you could also upgrade to a tensile! It all depends on how much money you have, If you can't go over £500 then buy a T-COMP and keep the frame it has already got, and put the rest of cash towards some sticky pads and better grips. Quote Link to comment Share on other sites More sharing options...
flas12345 Posted December 19, 2006 Report Share Posted December 19, 2006 hiya pal,there are quite a few desent mod's around for under £500. i went for the onza t-pro but there is the onza t-mag spec1 or spec2 not sure which one but they are good also. this year there is the new onza-tcomp which looks very nice and also has a good spec on it or you could get a second hand bike such as a zoo python for under £500 there is one on ebay now it is very nice and cheap for the components it has on it Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted December 20, 2006 Report Share Posted December 20, 2006 (edited) T-mag 06. The equevalalent monty was close 2 a grand. Nuf said Edited December 20, 2006 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
