Boswell Posted December 16, 2006 Report Share Posted December 16, 2006 I have slightly bent the rotor on my magura louise, any tips on getting it straight Mr ? Quote Link to comment Share on other sites More sharing options...
spode@thinkbikes Posted December 16, 2006 Report Share Posted December 16, 2006 Wrench and patience. Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted December 16, 2006 Report Share Posted December 16, 2006 If u get two flat surfaces put the rotor in between them then put that all in a vice........if that dont work do the same but this time heat the rotor up Quote Link to comment Share on other sites More sharing options...
Mike Beck Posted December 16, 2006 Report Share Posted December 16, 2006 (edited) 1. Get two solid and even plates of metal/or owt thats flat, put ur rotor in between and park a car over the top of it overnight. or2. Get an adjustable spanner and slightly bend back the bent bit slightly further than straight to make it straight.then wash it in hot soapy water and put back onto the bike.cheers lewis Edited December 16, 2006 by lewis69 Quote Link to comment Share on other sites More sharing options...
spode@thinkbikes Posted December 16, 2006 Report Share Posted December 16, 2006 Have either of you actually tried that method? (using a vice etc.)Because usually you have to go past the bend point to get it to stick, and I would expect the same when used in a vice. I'd be interested to hear if it works! Quote Link to comment Share on other sites More sharing options...
Muel Posted December 17, 2006 Report Share Posted December 17, 2006 Just use an adjustable spanner, then you don't have to take the wheel out of your bike, or park a cr of it overnight... Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted December 17, 2006 Report Share Posted December 17, 2006 find a little lip in the road and stamp on it.... please note this is only for desperate times, but worked flawlessly for me Quote Link to comment Share on other sites More sharing options...
St_trials Posted December 17, 2006 Report Share Posted December 17, 2006 Just move the caliper slightly, worked all of mine when they warped/bent Quote Link to comment Share on other sites More sharing options...
King C Posted December 17, 2006 Report Share Posted December 17, 2006 If its still ridable then just leave it. I find that mine straightens itself after a while. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 17, 2006 Report Share Posted December 17, 2006 If it's a diddy bend that rubs slightly, then just keep pulling the brake hard, but all round the rotor.So spin it, brake hard, rotate it, brake...etc. Quote Link to comment Share on other sites More sharing options...
moza Posted December 17, 2006 Report Share Posted December 17, 2006 With a little patience and an adjustable spanner you will have it straight soon as. Quote Link to comment Share on other sites More sharing options...
