Will These Middleburns Fit Ok?
Nuke Bowel
Hey. They should fit fine. You could either replace the spider with a middleburn pro-trials spider or just put a bash on the spider. You might want to check that there 5-arm compact rather than 5-arm standard. It's often hard to tell from pictures.
I think he means the thread has been crossed, but has then been re-tapped to sort it out a bit. Did it to a few cranks at my old work and they were fine after. Just depends how badly crossed it is. But as long as its not started stripping out the thread its normally fine.
