steve@banbury-trials Posted December 15, 2006 Report Share Posted December 15, 2006 hi,i got my new goodridge hose the other day,i managed to put and fit the main hose together easily but i can't get the barbed fittings into the crossover pipe has anyone had this problem to?and how did you solve it?any help grateful,steve Quote Link to comment Share on other sites More sharing options...
Muel Posted December 15, 2006 Report Share Posted December 15, 2006 Do you have a Magura Bleed Kit? As far as I am aware this is the only way to get the soft jaws needed for clamping the hose in a vice so that you can then tap the fitting in with a hammer.Have you tried dripping washing up liquid into the hose?If you need pics, check this out.http://cleanbikes.co.uk/FAQs/Fitting_a_splitter.htmThe link is for fitting a monty splitter, but you can pick out the bits you need.Hope This Helps! Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 15, 2006 Author Report Share Posted December 15, 2006 thanks for you reply,i'll give it a try as soon as possible steve Quote Link to comment Share on other sites More sharing options...
Muel Posted December 15, 2006 Report Share Posted December 15, 2006 No Problem Mate. Hope that this solves your problem, worked for me. Quote Link to comment Share on other sites More sharing options...
Muel Posted December 15, 2006 Report Share Posted December 15, 2006 Just had another little thought, rather than using washing up liquid and risking contamination of your mineral oil, why not use the oil to ease the fittings in! (It is oil after all...) Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted December 15, 2006 Report Share Posted December 15, 2006 (edited) 1. just make the clamp jaws yourself. Get a block of wood about 4cm x 4cm x 3 cm, drill a 5mm hole in the centre of it, then cross section it through the hole.2. clamp the hose in your new holder in a vice, leaving about 10mm of hose sticking out the top of the jaws use a little bit of wd40 on the barbed fitting and tap it in with a hammerRepeat step 2.job donegav Edited December 15, 2006 by Gavyn L Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 16, 2006 Author Report Share Posted December 16, 2006 thanks people for your tips and guidance,much appreciated cheerssteve Quote Link to comment Share on other sites More sharing options...
Danny Posted December 16, 2006 Report Share Posted December 16, 2006 Partz made a great video explaining this http://videos.trials-forum.co.uk/PaRtZ%20magura%20hosing.avi Quote Link to comment Share on other sites More sharing options...
