jonny_smith Posted December 13, 2006 Report Share Posted December 13, 2006 (edited) when you buy brake pads from tarty bikes do they come in a full set e.g. 2 for the front and 2 for the back or is it just 1 set because the prices seem a bit steep if its just 2 pads also does anybody know of a brake booster that fits on my forks, they are onza lite guy forks or is it not worth putting a booster on the front? Edited December 13, 2006 by jonny_smith Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted December 13, 2006 Report Share Posted December 13, 2006 its not really worth putting a brake booster on the front because the forks dont flex/bend when the brake is pulled, normally when you order brake pads of tartybikes they usually come in pairs, only 2correct me if im wronghope this helps Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted December 13, 2006 Report Share Posted December 13, 2006 All our pads are sold as one pair - 2 individual pads, this is the case for every trials shop I can think of (unless it specifies 4 pads, of course)!Adam Quote Link to comment Share on other sites More sharing options...
*BOOTHY* Posted December 13, 2006 Report Share Posted December 13, 2006 when you buy brake pads from tarty bikes do they come in a full set e.g. 2 for the front and 2 for the back or is it just 1 set because the prices seem a bit steep if its just 2 pads also does anybody know of a brake booster that fits on my forks, they are onza lite guy forks or is it not worth putting a booster on the front?Hi a brake booster for the front is not worth the money as they dont really flex anyway. Also the brake pads just come as 2 one for back or one for the front the reason they are steep is they are really good pads and different one work better on grinds or not.Jack Quote Link to comment Share on other sites More sharing options...
jonny_smith Posted December 13, 2006 Author Report Share Posted December 13, 2006 thanks for your help i'll save up and get some new pads because i like my brakes to be super sharp its how i've always had them set up n i'm used to it now and at the moment they aren't as i would like them. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted December 13, 2006 Report Share Posted December 13, 2006 i run a front booster!!!its for my echo control forks, i use it to keep the fok legs apart or otherwise my pad rubs against my rim really badlyi run echo control forks and try all rims, has abyone else had that problem??matt Quote Link to comment Share on other sites More sharing options...
jonny_smith Posted December 13, 2006 Author Report Share Posted December 13, 2006 i run a front booster!!!its for my echo control forks, i use it to keep the fok legs apart or otherwise my pad rubs against my rim really badlyi run echo control forks and try all rims, has abyone else had that problem??matt what booster do you use? Quote Link to comment Share on other sites More sharing options...
digo Posted December 13, 2006 Report Share Posted December 13, 2006 I think you could use most 4point boosters for 4point magura mounts. But if you have v-brake console, you can also use the original magura booster... Quote Link to comment Share on other sites More sharing options...
I-LUV-TRIALS Posted December 14, 2006 Report Share Posted December 14, 2006 I think you could use most 4point boosters for 4point magura mounts. But if you have v-brake console, you can also use the original magura booster...i think you mean 4-bolt magura mounts, also there is no need for a booster on the front.my advice-rear- booster and rock pads in blue on a medium grind front- disc= avid bb7 / maggie with tar hope this helps adam Quote Link to comment Share on other sites More sharing options...
