Hope Disc Rotors
Gandalf the Yellow
i got a 185mm caliper + rotor at the moment, but i want to whack it up to next size up + new rotor on it!
i quite like the look of the floating rotors but they seem to only do 203mm instead of 205mm, (what the hope mini SHOULD be running) would the -2mm rotor matter?
help me!!
steve
2mm of the pads would not wear, causing the pads to wear unevenly, should be fine though Ben Moore has done this for months on his avid.
Would only make 1mm difference on each side liam ;)
Yeah, it should be fine. lots of adapters such as the hopes alow a small amount of movement anyway so you should be able to fit it fine.
