Stripping My Forks...
newb
Hellooo,
Ive serched the forum for a removal guide and found one straight away,
My problem is that if i strip my forks down, wont they rust immediatly?
Please help because it pointless me stripping them and them then rusting...
Cheers,
Lewis. (Y)
Got echo lite forks, my bike has nothing standard except frame that is :P
Thanks for the help,
Lewis.
My dad says that if i strip them down ill have to polish them everyday because
Litlle dots of rust will start to appear
Not sure though :ermm:
Edited by newb
Your forks will 100% Not rust, There Alu and Alu don't rust I've stripped a few pairs of Alu Forks, There'll be fine. Just give them a good polish every month or so becuase they start to go dim and look rather old but once you've scrubbed them up abit with some Autosol (Metal Polish) There'll be looking brand new again.
Steel forks will rust but Alu forks won't, Echo Lites are made of Alu so they won't rust :) So your alright to go and strip them.
Maybe post some pics up, I've been thinking of stripping my Echo Lites :)
Edited by Ben@LeicesterTrials
O.T. thought the t-pro forks were chromoly
Chromoly is a type of steel ;)
Yeah, agreed, aluminium doesn't rust, it oxidises, but that's a good thing with aluminium as aluminium-oxide is a very hard wearing protective layer on the surface of the material, that just looks kinda dull. Can be polished up though, but like people say, it only lasts a few months.
You can strip them with caustic soda (thanks Ben for the advice) and polish them with no problem. They will oxidize creating aluminum oxide which as wrote before will protect the fork - you can call it self-anodizing if you wish but there's a slight difference between the two.
The forks will go matte and if you want to keep the high polish Mr. Gibson has, they will need a polish every now and then. Alternatively you can spray them with lacker but that will slowly peel off and look grotty.
