abtrials Posted December 7, 2006 Report Share Posted December 7, 2006 (edited) i am just wondering what front rim to use i currantly have a really thin mavic 717 xc rim but i am thinking of getting a wide rim? what is best? Edited December 7, 2006 by rwiley Quote Link to comment Share on other sites More sharing options...
guineasmithpig Posted December 7, 2006 Report Share Posted December 7, 2006 (edited) wide, with a fat tyremore boing from your bonks, and better grip/cushioning for gaps to front wheeli was running a koxx rear rim on a hope xc with a 2.35in dh tyre on the front! weighed a bit, but was grip-tastic! Edited December 7, 2006 by guineasmithpig Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted December 7, 2006 Report Share Posted December 7, 2006 (edited) A Koxx rear on the front??!? How did that steer?My advice would be a Planet-X LMF. They're about 30mm wide, reasonably light and very strong. As for a tyre, I use a Michelin Hot S, but you might get laughed at. Also I like an IRC El Gato on the front... Not super pinch resistant, but light weight.EDIT: And if you're looking for 32 holes, CRC do it for £19.99 - bargain! Edited December 7, 2006 by snappel Quote Link to comment Share on other sites More sharing options...
Broomer Posted December 7, 2006 Report Share Posted December 7, 2006 i dont rearly see the point of stupidly wide rims on the rear, let alone on the front. the mavic will be fine, im running a mavic 321 on the front of mine.unless your doing big front wheel stuff, maybe then you might want a slightly bigger rim. Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 7, 2006 Report Share Posted December 7, 2006 personally I dont got any narrower than 36mm on the front. if your riding street then I cant see you needing a ride front rim really, but if you ride natural you will like the extra grip and stability a wider rim gives. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 7, 2006 Report Share Posted December 7, 2006 I'm still rockin' a '97 Mavic X517CD and i'm definately consideing a wider rim...Though I run a 2.3 Tioga Blue Dragon and it grips well, but on natural it does get a little unstable at times. Quote Link to comment Share on other sites More sharing options...
abtrials Posted December 8, 2006 Author Report Share Posted December 8, 2006 cool i forgot to add i need a rim to fit a 28 spoke hub SORRY :$ Quote Link to comment Share on other sites More sharing options...
GTF Posted December 8, 2006 Report Share Posted December 8, 2006 Try-All?Mavic?Both make 28H rims. Both thin and wide Quote Link to comment Share on other sites More sharing options...
Damon W Posted December 8, 2006 Report Share Posted December 8, 2006 wide un wi a 2.35" maxxis tyre.helps wi natural, wen stuffs cok eyed, means tyres more stable.and gives the tyre a more square profile which is better grip then its rounded counterpart RAILS!!!!! Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 9, 2006 Report Share Posted December 9, 2006 i prefer wider rims to thin ones ,just because it think it feels more stable than a thin rim.steve Quote Link to comment Share on other sites More sharing options...
manuel Posted December 9, 2006 Report Share Posted December 9, 2006 thin - lighter (and probably just as strong if you get a mavic) and less rolling resistance.... get a skinny mavic and a 2.35 single ply maxxis. Quote Link to comment Share on other sites More sharing options...
abtrials Posted December 9, 2006 Author Report Share Posted December 9, 2006 thin - lighter (and probably just as strong if you get a mavic) and less rolling resistance.... get a skinny mavic and a 2.35 single ply maxxis.i have a thin mavic 717 (i think) at the mo so i might just invest in a decent tyre for the front, ive seen your style and it is sweet as so i guess it works Quote Link to comment Share on other sites More sharing options...
