Zhi Zm1
lawrence osborn
im not sure it will be certainly good for bunnyhops, davetarty uses t-master stem and loves it not sure about what bars though. i would think if your going to run a high rise/reach stem dont get such big riser bars, get something with a little less rise such as onza risers.
He never said mod or stock :P I was assuming stock as I ride one amd tarty just got them in.
But he said ZM1, rather than Z1, the M indicates that it's a mod???
I duno, your the one who rides one...... :P
:rolleyes:
Monty stem and zoo bars?
Getting there, but the monty stem is fairly low rise relatively speaking, and the zoo bars havn't too much rise either, maybe with onza bar's, or those BT ones seem fairly cheap and have alright geometry...
Should be fine, matey (Y) . It will make the bike more controlled as your arms (handlebars) won't be as close to your feet (bottom bracket). This is recommended with a high bottom bracket rise frame.
Hope that helps...
Cheers,
Joe. :)
Should fit. I'd expect the Zhi is 116mm dropout spacing, so as long as you put some snailcams in there it'll be fine. :thumbsup: If you haven't already got the wheel though, then dont bother, the hubs are gash and the bearing surfaces have a habit of caving in. (N)
  • 2 weeks later...
