Captain Scarlet Posted December 6, 2006 Report Share Posted December 6, 2006 Hey Guys,I was thinking about getting a new rim for when I get my Onza T-vee (07).I want a 19" so its nice and thick, but I got a few questions to ask.1) Will a 19" rim fit an Onza T-vee2) Will a need a new innertube3) Will Magura's still work/be adjusted to fit the wheel4) What size tyre will I need for it, and what do you reccomend I should get as an affordable one. Thanks in advance.-Tom Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 hiya mate,1/ 99% sure it will, i had a t-bird and it did and there v. similar 2/ No.3/ Yes they will still fit, need to be adjusted/moved down more probably.4/ Maxxis Creepy Crawler from tartybikes.co.ukHope all works out Hope this helps.Mat Quote Link to comment Share on other sites More sharing options...
Rupertbear Posted December 6, 2006 Report Share Posted December 6, 2006 i always thought the t-vees had 20inch rims front and rear, this meaning it will not fit because the brake mounts will be too high, correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 Well so did my t-bird but then i brought a 19" wheelbuild for it and then you just have to re-arrange the mounts, i.e. slide them up/down in order to aline the pads against the rim properly Mat Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted December 6, 2006 Author Report Share Posted December 6, 2006 Hehe thanks for the help guys.I should buy myself a new wheel hopefully in the new year, thinking about an Onza Hog rim. Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 No problemGet some pics up when your done Mat Quote Link to comment Share on other sites More sharing options...
Rupertbear Posted December 6, 2006 Report Share Posted December 6, 2006 looking at the onza site the t-bird has a 19inch rim and the t-vee has a 20, the 19inch rim will not fit on the t-vee Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 No mate, it will, sorry i forgot to mention i had the old t-bird It had a 20" with maggies set up fine, then i brought the 19 and the maggies were set up fine and working again. Sorry!Mat Quote Link to comment Share on other sites More sharing options...
mark145 Posted December 6, 2006 Report Share Posted December 6, 2006 No mate, it will, sorry i forgot to mention i had the old t-bird It had a 20" with maggies set up fine, then i brought the 19 and the maggies were set up fine and working again. Sorry!Mat Sorry mate your wrong I went to my LBS a couple of months ago after asking the same question (should of used the search ) And they said since the first ever T-bird the rims have been 19". So anyway I would say just get maggies for your T-vee or save and get the T-bird and you'll be fine. There is not much of a point getting a 19" IMO unless your rim cracks or etc. Plus if your just starting out you wont need a new rim, and your probably worth getting a stem or handlebar setup instead. Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted December 6, 2006 Report Share Posted December 6, 2006 yeah you coudn't run a 19" on the t vee the frame wouldn't have enough clearance for the tyre and as said befor the t bird comes with a 19" rim Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted December 6, 2006 Author Report Share Posted December 6, 2006 Well the T-Bird and T-Vee are basically the same frame, just different paintjob.If a 19" can fit on a T-bird then I'd imagine you could for a T-vee? Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 Once again sorry! I just remembered that i got skanked and sold a t-bird that had bmx wheels on it! So mine did have a 20" wheel on it maggies did work, then my 19" wheel was fitted with bigger tyre and that still worked with the brakes But agreed that it's not really worth the effort! I think maggies are a good idea or yer, the t-bird Sorry for the mix up guys!Mat Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted December 6, 2006 Author Report Share Posted December 6, 2006 I think maggies are a good idea or yer, the t-bird Sorry for the mix up guys!MatI would get the T-bird, but the 07 model doesn't come with Magura's as standard so I might as well go for the Vee. Quote Link to comment Share on other sites More sharing options...
ZOO!PYTHON Posted December 6, 2006 Report Share Posted December 6, 2006 perhaps the 06 model? Or second hand one with maggies?Cheers Mat Quote Link to comment Share on other sites More sharing options...
bionicman Posted December 7, 2006 Report Share Posted December 7, 2006 this topic has been done before but yes a 19" wheel will definatly fit on a t-vee and you dont need new tubes but you need a creepy crawler or some tyre like that Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 7, 2006 Report Share Posted December 7, 2006 T-Birds didn't start with 19" rims.When I had my '02 T-Bird, it came with a 20" rear wheel.I upgraded it to a 19" wheel, as the Magura mounts were in the position for a 19" rear wheel, and the V's that came on it were for it's 20" one.As the T-Vee has V mounts on it, you might have difficulty setting up the brake for the 19" wheel.I'm not saying it can't be done, as I've never tried it. If people on here say they've done it, then go for it. Quote Link to comment Share on other sites More sharing options...
abtrials Posted December 7, 2006 Report Share Posted December 7, 2006 it will fit defo i have a friend who has dont the same thing? just do it i dont think the people who are saying it wont know about it reallyplus its only 25 for a 19" rim and about 20 for a tyre hardly going to rob the bank a? Quote Link to comment Share on other sites More sharing options...
ruckus_street Posted December 7, 2006 Report Share Posted December 7, 2006 T bird frame is not the same as the TveeTvee has vee mounts (funny that lol)and the T bird has 4 bolt maggie mountsDon't think brakes are as easily moved down with 2 bolt v-mountsSo if i were you, i'd borrow a mates wheel for a few minutes and stick it on, see if it works Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted December 7, 2006 Author Report Share Posted December 7, 2006 I'm talking of the 2007 models of T-Birds and T-Vees.ruckus_street, the 07 T-Birds only have 2 bolt mounts, not 4 like some of the previous T-Birds. Quote Link to comment Share on other sites More sharing options...
David20 Posted December 7, 2006 Report Share Posted December 7, 2006 Won't work mate. Quote Link to comment Share on other sites More sharing options...
ruckus_street Posted December 7, 2006 Report Share Posted December 7, 2006 (edited) well either way, ur best bet is to try it with a mates wheel first if you can, otherwise, it'll be a real hassle if it doesn't workIf it does, let us know, im curious loland also, Are u fitting maguras to the tvee when u get it? Edited December 7, 2006 by ruckus_street Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted December 7, 2006 Report Share Posted December 7, 2006 it does workyou may need to deepen your horizontal dropouts a tad though, so basically continue the slot for another cm, and thatll bring the wheel into a position to where the 19inch wheel will set up fine for the mounts ive put a 19inch wheel in a t vee, and run the brake fine, its not difficult Quote Link to comment Share on other sites More sharing options...
