STC Posted December 6, 2006 Report Share Posted December 6, 2006 hey,do any of you lot have a ny good idea of what crank and bash I should get for my bike after christmas?I ride a onza t-rex 05 customCheers,Luke Quote Link to comment Share on other sites More sharing options...
abtrials Posted December 6, 2006 Report Share Posted December 6, 2006 burns are good, also have a look at tartybikes.co.uk they have all sorts, have a look at the echo 6061 forged cranks, echo 7075 bashgard, and echo screw on sprocket.this is well worth it Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted December 6, 2006 Report Share Posted December 6, 2006 i love my tensile urban legends ,there strong and lightweight and available in 165mm ,170 mm and 175mm what else can you ask for ?steve Quote Link to comment Share on other sites More sharing options...
trials_mad Posted December 6, 2006 Report Share Posted December 6, 2006 I'm not sure what you are running whether it be ISIS or not but if you are running square tapered then i would reccomend that you should buy an ISIS bottom bracket and then get ISIS cranks. Reason being is that i have rounded 2 pairs of square tapered cranks and with ISIS this will not round as easy. I would say get the echo 7075 bashring as it is reasonably and you get a choice of trendy colours. (hint hint gold ) Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted December 6, 2006 Report Share Posted December 6, 2006 I'm not sure what you are running whether it be ISIS or not but if you are running square tapered then i would reccomend that you should buy an ISIS bottom bracket and then get ISIS cranks. Reason being is that i have rounded 2 pairs of square tapered cranks and with ISIS this will not round as easy. I would say get the echo 7075 bashring as it is reasonably and you get a choice of trendy colours. (hint hint gold )Not being funnyBut if you keep your cranks tightIt wont happen... Quote Link to comment Share on other sites More sharing options...
trials_mad Posted December 6, 2006 Report Share Posted December 6, 2006 Not being funnyBut if you keep your cranks tightIt wont happen...They were as tight as i could get them, obviously not enough Quote Link to comment Share on other sites More sharing options...
stug45 Posted December 6, 2006 Report Share Posted December 6, 2006 ive had both isis and square taper go wrong on me but then again when i got isis it was very cheap isis stuff. gonna put my burns and new bb on tomorrow so as long as they go on tight ill love itbut isis it better than square taper for trials cos of the power u put in! Quote Link to comment Share on other sites More sharing options...
Broomer Posted December 6, 2006 Report Share Posted December 6, 2006 (edited) myself and alot of other trials riders that are using square taper have no problem, id guess the cranks you rounded were cheap? cheap cranks will round because the alloy is cheap, higher range cranks will not. Edited December 6, 2006 by Broomer Quote Link to comment Share on other sites More sharing options...
