Monty Or Gu Forks & A Little Prob
powerz
Hi all,
I currently have Monty 221 Pro disc & magura mount forks on my GU would it be worth me buying GU forks.
Also the last few days i have got an annoying ticking sound for example (like a broken bearing in the hub) but yesterday i stripped the hub down cleaned it all out fitted new bearings and re greased it but the noise is still there.
Do you think it could possibly be my pedal or maybe take my freewheel apart and re-grease it.
What do you think, Any sugestions?
Thanks in advance for taking the time to answer these questions (Y)
Hi all don't worry i have found the problem and all i can say is OH BUGA, I took my hub apart this morning to find out what the dodgy ticking noise is as i went out last night and i was really annoying me plus now and again it made a real bad crunch sound (N)
anyway the problem is the rear sprocket where the bearings sit, it's cracked in 5 places which means the new bearings i put in yesterday are going to be bugered too. Cant believe i didn't notice the cracks yesterday when i cleaned,re-greased and replaced the bearings oh well S**t happens
This really sucks as i'm meant to be going on a ride the weekend, but i have ordered a new rear sprocket from The Trials man so hopeful it may turn up in time.
