dwarrick Posted December 6, 2006 Report Share Posted December 6, 2006 ok so i have a rear 07 echo mod hub. it was made with the first batch of hubs and has a weird design that it unique only to that batch compared to every other hub ive seen. the hole that the snail cam has to go onto the hub is alot bigger than other tensionners and cams. i got some thresholds that HB trials milled out to a new hub not knowing the difference in size and they dont hit on my hub.Anyone else know about this problem? Am i stuck with these snail cams that came stock on my bike as the only option avalible?pics for help. green one is my style hub, blue one is the new style Quote Link to comment Share on other sites More sharing options...
IOLO Posted December 6, 2006 Report Share Posted December 6, 2006 i dont get it.try doing a paint drawing, lolor take a pic with a cardboard dropout, so i get it. loliolo. Quote Link to comment Share on other sites More sharing options...
python_man Posted December 6, 2006 Report Share Posted December 6, 2006 Do you mean you don’t know how to set it up you must use snail cams you can’t use the usual chain tugs.Not sure what you mean though can you clarify for us? Quote Link to comment Share on other sites More sharing options...
theone2be Posted December 6, 2006 Report Share Posted December 6, 2006 Me no understand your predicament Quote Link to comment Share on other sites More sharing options...
GyTrials Posted December 6, 2006 Report Share Posted December 6, 2006 Think he means the tensioner he has got wont fit on his hub as its a different model and the spindle is to large (looks that way in the picture) couldn't you just enlarge the hole in the tensioner to fot over the spindle? Quote Link to comment Share on other sites More sharing options...
dwarrick Posted December 6, 2006 Author Report Share Posted December 6, 2006 (edited) Gytrials has the idea. you you look at the first pic of the hubs, look at the holes where the bolts go though. the green one is much larger than the new style ones which seem to be the standard for all hubs. if i were to make the holes in the threshold any bigger it would be way to weak. you can see in one of the pics how close it is to the edge already and it has to be quite a bit bigger. Edited December 6, 2006 by dwarrick Quote Link to comment Share on other sites More sharing options...
