owain bowles Posted December 4, 2006 Report Share Posted December 4, 2006 hii have got tektro alloy v brakes and wondered if i had to change them fastthanks owain Quote Link to comment Share on other sites More sharing options...
*BOOTHY* Posted December 4, 2006 Report Share Posted December 4, 2006 I would do as v brakes can be really good but sometimes in different weather they can be really rubbish so i would recommend a hope mono trial or mono mini on the front and a magura hs33 on the back.Jack Quote Link to comment Share on other sites More sharing options...
owain bowles Posted December 4, 2006 Author Report Share Posted December 4, 2006 thanks how much are they and where can i get them from Quote Link to comment Share on other sites More sharing options...
c.kezer Posted December 4, 2006 Report Share Posted December 4, 2006 you can get your brakes on tartybikes.tartychris Quote Link to comment Share on other sites More sharing options...
ytr_rich Posted December 4, 2006 Report Share Posted December 4, 2006 just get yourself a pair of maggies you cant go wrong rich Quote Link to comment Share on other sites More sharing options...
dan_barnett Posted December 5, 2006 Report Share Posted December 5, 2006 dont keepthem brakes get some magies Quote Link to comment Share on other sites More sharing options...
melvin146 Posted December 5, 2006 Report Share Posted December 5, 2006 if you have a litte bit of money to spend i would say get an avid bb7, or any type of disk for the front!cheers chris Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted December 5, 2006 Report Share Posted December 5, 2006 I would do as v brakes can be really good but sometimes in different weather they can be really rubbish so i would recommend a hope mono trial or mono mini on the front and a magura hs33 on the back.Jackmaguras dont work perfectly in the wet either tit...anyway, just get yaself a decent rear cable, like an oddyssey linear slick, and some decent rear pads from heatsink bikes or plazmatic, its cheaper than going to maguras, and your brakes will work tons better also perhaps invest in a deore/sd7 rear calliper and try and find a higher end shimano/avid brake lever for the rear, thatll help no end, its worth investing in a decent rear v set up if you want reliable braking Quote Link to comment Share on other sites More sharing options...
