Pedal Hopping
twokn6
if you don't have the money for the dvd or just cant be bothered here you go:
start by doing a track stand and with a firm pedal cick bring the front wheel in the air
then let the front wheel drop let the rear brake off a little and pedal stroke again to make the wheel rise then pull your back brake and let the front wheel drop and repeat as long as you can this will help you gain confidence on your back wheel and learn to control
when you are confident with that repeat the first 2 steps but before you leave go of the brake crouch a little in the bunny hop posistion and pedal cick bringing the bike up with you then shift 60% of your weight over the back wheel to keep you up
if you feel uncomefetuble doing the pedal cick to get the wheel up do a couple of back hops to set you off
hope this help m8
sean (Y)
i'd reccomend "the art of trials" by mr ryan leech (Y) great dvd,i think you can buy it from halford for around £20 .you can also try trashzen website ,like the dvd just on the net.steve
Hi
Don't buy it you can watch the hole thing in parts on youtube the best bit is is you can watch just what you want to now.
just go on www.youtube.com then type ryan leech in go through all of them you will find every thing.
hope it helps.
dan
Edited by dan the trials man
