Saracen Kid Posted December 3, 2006 Report Share Posted December 3, 2006 i've heard about make a single speed kit from 2 cassetes them splitting them and choosing a cog and so on and so on but how do you split a cassette? Quote Link to comment Share on other sites More sharing options...
huge Posted December 3, 2006 Report Share Posted December 3, 2006 On the back of the largest cog you should see 3 pins or small screws. If your cassette has three pins then file the tops carefully until the pin slides through the other cogs and out of the other side (smallest cog end) . If your cassette has 3 small screws-most shimano cassetes-use a small allen key to remove them and then the cassete should fall apart leaving you with cogs and spacers Quote Link to comment Share on other sites More sharing options...
Rupertbear Posted December 3, 2006 Report Share Posted December 3, 2006 there is three pins holding the cassete togethor grid the tops of these pins and it will fall apart, bobs your uncle you have a single speed kit. Quote Link to comment Share on other sites More sharing options...
Saracen Kid Posted December 3, 2006 Author Report Share Posted December 3, 2006 have you guys done this / seen someone do it Quote Link to comment Share on other sites More sharing options...
Rupertbear Posted December 3, 2006 Report Share Posted December 3, 2006 yeah my jump bike was like it for months Quote Link to comment Share on other sites More sharing options...
dan the trials man Posted December 3, 2006 Report Share Posted December 3, 2006 have you guys done this / seen someone do itYes my zoo has it and it rides smooth, mine came like it when i bought it second hand it has just the one cog and then spacers to fill in the gaps . Quote Link to comment Share on other sites More sharing options...
gundam Posted December 3, 2006 Report Share Posted December 3, 2006 Its very easy to do and works well, my bike has been like it for ages. If the cassette is held together with pins the easiest method is just to drill the heads off them, this way you will hardly touch the cog Quote Link to comment Share on other sites More sharing options...
paolo Posted December 3, 2006 Report Share Posted December 3, 2006 I'd personally buy a large base cog because the cogs from a cassette can chew up your freehub body because they are made to spread the force across the hole cassette. Anyways, the guys on top got it right. Quote Link to comment Share on other sites More sharing options...
stug45 Posted December 3, 2006 Report Share Posted December 3, 2006 u also need spacers so that the cog you choose from the cassette doesnt move from side to side. most spacer kits including this one: LINK come with a cog anyway Quote Link to comment Share on other sites More sharing options...
