Using My Sd Memory Card As A Sort Of Memory Stick?
Davetrials
Yeah most photo shops have a booth that takes all kinds of memory cards - you stick it in and select the pictures you want etc. You don't even have to use your computer first, straight from the camera is fine. Even Tescos have some booths.
yes but i want to EDIT the pictures so that means they will have to be take OFF the camera.
right up load them to your pc, edit them, select the ones you want and copy them then literally go into my computer selec the sd card (will come up as another drive in my computer) and just paste them to it. voila, new edited pics on there card. obviously you can get rid of the ones you dont want on there.
craig
Yeah yeah... I said you COULD do them straight from the camera, you don't have to. As long as they're saved as jpegs (or maybe TIFFs?) it'll be fine.
