Tension + Wheel Alignment
Token
Evening all,
Having abit of trouble with keeping my chain tight and also keeping the wheel in line so the brakes don't rub, doesn't seem I can have both tension and alignment just the way I want it. Have to sacrifice one for the other.
I'm using fresh products snail cams, ones with quite big notches, so aligning the wheel for the brakes can be abit of a biatch because the wheel moves so much when you move the cam just one notch.
I've already got a solution I think.... somewhere hidden I've got a set of Echo snail cams, totally notchless (so aligning the wheel will be alot easier than having the fresh products big notches moving the wheel left or right quite alot, should be able to perfect it :S ) I'm abit sceptical of using them because I'm guessing they will slip, being notchless, am I wrong?
Cheers guys x mat
I had the Echo cams Matt and they didn't slip at all, just make sure you do your shoddy little bolts up tight and it should be fine. Maybe run the wheel slammed against your dropouts and take a few links out of your chain? Might simplify matters if you can take the right amount of links out but it is also tad dodge playing with the one thing which keeps your face from becoming a pile of shit.
Love you :)
I have the FP cams, and the only problem i have is that they were hard to turn.
Your better off setting up the wheel stright, and getting a good chain tension, and thenset up the brake. There's no way the wheel is going to move with the FP cams.
(Y)
Thanks for the replies guys,
Sorry I didn't mention before, I have a xtp running a 47mm wide echo rim. For some reason I have to run the magura cylinders pushed right out of the clamps to stop the brake rubbing, probally because I've got 8mm pad life and there just isn't enough room for abit of 'play'. Anyway think I've cracked it, just, until I land sideways and get a buckle. :(
You ever bothered using the flat side of a angle grinder to rub pads down? I tried it with a unevenly worn Koxx Brown, made the pad go shiney but also produced aload of black smuck on some parts of the pad :S so not sure if that's totally ruined it. Can you do us a favour an post a link to the tensile offset clamps?
cheers mat x
Mate, I had EXACTLEY your problem, couldn't run full sized pads at all and got some of the offset mount's from supercycles, they are not advertised online as far as I know.
I threw up a mini review of them yesterday.
http://www.trials-forum.co.uk/forum/index....p;#entry1107146
I had to grind my heatsink blue's before putting them on, didn't f**k them up at all really.....
I found FP snail cams pants. When i used my smooth snail cams i hated them they always slipped but tartydave ran then and really tightened the bolts up so they can be used. I found the monty ones to be the best they have notches and the notches are alot smaller than the FP ones making it alot easier to adjust it precisely. I did a snail cam review in n/m chat a while back you could try and search for that and see if it helps at all.
I got mine from cleanbikes, not sure if tarty will have them in yet seeing as they have only just started selling monty, but cleanbikes have them in, and supercycles will have the offset mounts (Y)
Edited by andy h
I doubt he'll need both, the offset mount's should move the brakes enough to let him use the FP cams, unless each notch makee the rim move 5 mm to the left or right , which I doubt.
