Just A Quick Car Question
PaRtZ
My exhaust fell off today, just after the clampy bit. I gathered it was through rust and age although its not that old. Anyway, I just need to replace the last bit of the exhaust shown here:
[attachmentid=8458]
How much it gonna cost me?
at a guess, no more than £40, got a corsa back box last week from CES, at trade price, was £16, so call that £24 retail, cant see it being a lot more than that for the part itself. then its just fitting
however if its a crack, and there plenty of pipe (an inch plus) either side of the crack, get yourself a 4 pack of stella's, drink em all, cut the tops and bottoms off the cans, and cut straight down them, so you got rollable sheets. 2 jubilee clips, and roll the sheets of tin round the pipe, so the join sits on alternating side with each of the sheets, then clamp each end with the jubilee clip, its good for a thousand miles + like that, and costs no more than a fiver.
other options, scrappy, at a guess mild steel box will be £12-15, and a stainless box will be around £20 tops.
If it's that far back, I doubt you've dropped your cat, it's probably jsut the back box. Depending on condition of the pipe, they may be able to re-weld it for you. But eqaully, if it's going to do the same ina few months, might just be worth getting an entirely new pipe.
sorry which bit is the back box?
but £40 seems like the answer to me :) although I do like the stella idea.....
EDIT ok im a bit of a noob I got confused between the cat and back box. My car doesn't even have a cat lol.... just pretend the word "cat" on the daig says "back box"
Edited by PaRtZ
Hmm Well its been done now all works fine. Cost me £75 for a new pipe, the cat + back box were fine
so this pipe better be sparkly ;)
£75 just for a centre pipe?? sounds like a rip off, even if it is fitted, remember a couple of years back mother had her centre pipe on her xsara fail, local company fitted a new pipe and supplied it for £32.
