lawrence osborn Posted November 30, 2006 Report Share Posted November 30, 2006 Hey guys,as i need some new cranks i'm thinking of these cranks. I'm wondering if they are worth the money? also could i run this bash ring with a freewheel aswell and what tooth would i need?cheers lawrence Quote Link to comment Share on other sites More sharing options...
David Biddle™ Posted November 30, 2006 Report Share Posted November 30, 2006 yes they will fit on the crank but u might have to get a longer bottom bracket sow the freewheel dosent rub on the bracket cap Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted December 1, 2006 Author Report Share Posted December 1, 2006 anyone else know anything, and can anyone recomend a bb Quote Link to comment Share on other sites More sharing options...
basher Posted December 1, 2006 Report Share Posted December 1, 2006 (edited) Yes will all fit and pritty much all mod riders use 18:12 gearing so 18 tooth freewheel is what i would surgest you get. You will be best off getting a 127.5 bb and just a 10quid one from tarty will do. Squared tapered bb's are all the same really there isn't a expensive one really. If your getting isis then try all or echo seem pritty good not really heard bad things about them. Edited December 1, 2006 by andy h Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted December 3, 2006 Author Report Share Posted December 3, 2006 Yes will all fit and pritty much all mod riders use 18:12 gearing so 18 tooth freewheel is what i would surgest you get. You will be best off getting a 127.5 bb and just a 10quid one from tarty will do. Squared tapered bb's are all the same really there isn't a expensive one really. If your getting isis then try all or echo seem pritty good not really heard bad things about them.so i could run a bash ring and freewheel then? Quote Link to comment Share on other sites More sharing options...
