bikerben Posted November 27, 2006 Report Share Posted November 27, 2006 hi all,im getting a new rear wheel and i need to get my fixed cog off my old wheel i was thinking a chain whip to remove the cog but i dont think it will be strong enough to remove the cog as it has been fixed onto the hub for quite a while any other ideas or tips to get the cog offhelp appreciatedthanksben Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted November 27, 2006 Report Share Posted November 27, 2006 Wrap a few links of olc chain around it, clamp it in a vice, and give it some beans! By that, I mean try to turn the wheel as hard as you can, without ripping the spokes off. Quote Link to comment Share on other sites More sharing options...
JT! Posted November 27, 2006 Report Share Posted November 27, 2006 My advice would be don't bother.Just buy a new one, it really is a lot of haslte. Quote Link to comment Share on other sites More sharing options...
samo Posted November 27, 2006 Report Share Posted November 27, 2006 easy to just get a chain whip they only cost about £6-7 from the screw-fix magazine and then you have got it for life or just got to your local bike shop and i there nice they should do it for you for free.hope i helped Quote Link to comment Share on other sites More sharing options...
bikerben Posted November 27, 2006 Author Report Share Posted November 27, 2006 nar aire valley cycles will charge Quote Link to comment Share on other sites More sharing options...
JT! Posted November 27, 2006 Report Share Posted November 27, 2006 easy to just get a chain whip they only cost about £6-7 from the screw-fix magazine and then you have got it for life or just got to your local bike shop and i there nice they should do it for you for free.hope i helpedYou wont have it for life, you'll have it untill you try and remove the cog, and then you'll realise that they arn't designed for that at all when you brake it. So, yeah, chainwhip's no good. Quote Link to comment Share on other sites More sharing options...
T-OM Posted November 27, 2006 Report Share Posted November 27, 2006 easy to just get a chain whip they only cost about £6-7 from the screw-fix magazine and then you have got it for life or just got to your local bike shop and i there nice they should do it for you for free.hope i helpedmy mate dame tried to get a fixed cog off his hub with a chain wip and its almost impossible, this is because when your riding around the cog tightens onto the hub emensley, so my advice is to put it in a vice and turn the wheel clockwise or if you dont have access to a vice go to your local bike shop. Quote Link to comment Share on other sites More sharing options...
pike64421 Posted November 27, 2006 Report Share Posted November 27, 2006 hello people. The way i got my fixed cog off on my hub was that i i got a empty butter tub and i filled it up with DW40 and put the wheel lying on top of it so the cog to was covered left it for a day to soak. I got a lenght of chain put it on the cog and had a peace of steel tubing with a small bolt thought it i hooked a link in the chain on the bolt to make like a home made chain whip while i was trying to undo it i was taping it with a rubber hammer on the centre of the cog. After a bit of sweat it came off. but personally i would just buy a new one because u are putting that much strain on it u would have weakened it so much Quote Link to comment Share on other sites More sharing options...
maxi Posted November 27, 2006 Report Share Posted November 27, 2006 ezi just get a blow torch and heat it up so then you expand it then get a chain wip and lewsen it of and thats the best way Quote Link to comment Share on other sites More sharing options...
onza t-jammy Posted November 27, 2006 Report Share Posted November 27, 2006 if you could help me too i need to know this as i will be doing a lot of it very soon !!! Quote Link to comment Share on other sites More sharing options...
