What Pads
maxi
ive said it again and again people...
Phat pads in cnc backings is where its at.
Max...
Don't suppose you'd know whether you can get them in just standard plastic backings? I cant afford cnc backings :$ . Also you running them on a grind? smooth? tar? Give us abit of info about them aswell :)
mat
Max...
so your bloody awake now!!! i was chatting to your mum on msn you queer!
anyway, zoo pads are good on a smooth rim, last ages on a smooth, but last a weekend on a grind! the blue rock pads last ages on a grind and work super.
mat
Available from 'fat' Mike Singleton at £9 a pair and available in plastic backings.
£29 for the cnc backings.
£9 for the plastic backings.
good wear rate and tremendously loud!
Edit: sorry.I am running them on a light grind on a dx32 rim and i have gave a pair to my friend and he is using them on a stock bike also with a ground Try all rim and great success.
No tar needed and work just as well in the wet.
hahaha, yer i was asleep.had a savage headache and sore throat..(too much oral sex but o well)
Max...
Edited by max-t
:P:- haha max has sex with me all the time he loves it :-:P well any ways he has lent me a pair in plastic backing ant there awsom i use no tar just a medium light grind if you can afford it get the cnc backings might work better in the long run but the plastic baking are amazing no tar needed just a grind
(argos £14.99 grinder got a good disc ) yer fat pads ***
ohh and i forgot i tried them in the wet last night there awsom
Edited by koxx 20" 26" rider
:rolleyes::lol::blink: yeye laides good 1 u g*ys
ye ye u queer yourself (Y)
pad review section should have you answers
wheres that??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? (Y)
At the moment im running toxsin pads on the rear, they are so good and so sharp that im sticking to them every time i get a new set of pads. There available from www.trialfutur.net only for a £10. If your ask me i would definatley recomend them
do they last long???
cheers maxi (Y)
