Trojan Hourse Found!
SCOTTY___
Right got a trojan house called NewDotNet and its located in the c:\programefiles\newdotnet\newdotnet7_22.dl
I've used ad-a-ware and i'm using The Cleaner and Norton, The Cleaner finds it, and locates it for me, but it wont quarantine or Clean and delete!
I got it through MSN with a link being sent, and me being a stupid fanny clicked it! My GF also has the Virus and we both cant get rid!
My GF has tryed the same as me including SPYBOT seek and destroy but it also wont delete it!
Anyhelp is VERY appriciated!
<333
I had same problem with mine and a mates computer, no spyware program would get rid of it. finally located where all the files were, .dll .exe's in system32 folder and used Eraser LINK to overwrite the files using the Guttmann (Default), Pseudorandom Data and US DoD 5220-22.M methods making it impossible to read the file.
If at first it says cant delete because the file is in use Eraser should give you an option to delete the file at next start up before it can be run.
Hope it does some good for you, worked for me :turned:
avg anti-virus software gets rid of it most of the time or there are Trojan horse removers downloadable from a Google search I always have to sort my lil sisters pc out after she got eight Trojans <_<
Good luck though mate
At least you don’t have a bad one there are Trojans that can open and close your cd drive and do worse things than that
At least you don't have a bad one there are Trojans that can open and close your cd drive and do worse things than that
seeing as a trojan is designed to open ports on your computer so someone, somewhere, is able to take remote control over your computer I'd regard having my cd drive being opened and closed quite alright really, seeing as they could be storing kiddie porn on somewhere. :(
