bikerider Posted November 23, 2006 Report Share Posted November 23, 2006 HISeeing as Tarty's are out of tensile bashrings, are they any other shops out there that sell them? Tried trialshop.co.ukIf not, can anyone recommend anything similar / better?Other problem, my isis bb is a bit stiff, it's supposedly a virtualy new one, and i doubt anything's broken. Do I need to remove and grease something? Or just ride the damn thing and let it bed in?....thanks Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 23, 2006 Report Share Posted November 23, 2006 Correct me if I'm wrong, but Tensile bashrings have a special fitting to go with the crank. I'm not sure if they can be used with other cranks? Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted November 23, 2006 Report Share Posted November 23, 2006 That Bottom bracket is it? I found my old style Echo one to be very very tight. Quote Link to comment Share on other sites More sharing options...
King C Posted November 23, 2006 Report Share Posted November 23, 2006 Correct me if I'm wrong, but Tensile bashrings have a special fitting to go with the crank. I'm not sure if they can be used with other cranks?I think he means the 20t screw-on ones. Have you tried Supercycles? Quote Link to comment Share on other sites More sharing options...
bikerider Posted November 23, 2006 Author Report Share Posted November 23, 2006 (edited) Sorry should have said, it's this oneand the bottom bracket is a shimano oneEDIT: Must be an FSA platinum one then thanks again Edited November 23, 2006 by bikerider Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted November 23, 2006 Report Share Posted November 23, 2006 Sorry should have said, it's this oneand the bottom bracket is a shimano onethanks againsince when have shimano made isis bbs? i know they do octalink, but thats a different interface Quote Link to comment Share on other sites More sharing options...
Bergia Posted November 24, 2006 Report Share Posted November 24, 2006 Try Aire Valley Cycles they should be able to sort you out with a Tensile bash Have you had a look on Supercycles as well? Quote Link to comment Share on other sites More sharing options...
Nick Garland Posted November 24, 2006 Report Share Posted November 24, 2006 Tarties are getting the 18T back in stock in about 9 days. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted November 24, 2006 Report Share Posted November 24, 2006 Says there in stock now. And yeah, that's normal with FSA BBs, there all stiff for a while until the seals bed in. Quote Link to comment Share on other sites More sharing options...
bikerider Posted November 24, 2006 Author Report Share Posted November 24, 2006 Says there in stock now. And yeah, that's normal with FSA BBs, there all stiff for a while until the seals bed in.Just checked, they only have the 20t. thanks for your help, phoned tart's today, and put one on pre-order for next week. Quote Link to comment Share on other sites More sharing options...
