Brake Fluid
TonyB
Might be a stupid question but I was wondering why hydraulic brakes use mineral oil instead of standard brake fluid (like Dot 4 or Dot 5). I can only think that brake fluid would corrode or damage some of the components on Maguras or whatever. Anyone know the answer?
Tony
Magura and shimano systems use mineral oil, while others like Hope and Hayes use Dot fluid.
Mineral oil could be considered the better fluid, as it has better lubricating properties, and is not hygroscopic, so does not need to be changed anually to keep it at its best.
The brakes that use dot fluid tend to be from more 'industrial' companies or ones from a motorbike background.
What fluid it is doesnt make much difference to the feel of the brake, but you must use the correct fluid in the correct brake, otherwise parts will get damaged- mainly seals.
