Phil H Posted November 20, 2006 Report Share Posted November 20, 2006 Right I need to buy some cranks. I've got a middleburn sprocket and a bash to go on which are both 5 bolt. BUT looking on tarty all the cranks look like left side cranks to me Do you screw on the actual 5 bolt thing to which you bolt the bash and sprocket? (surely they arent all like special branks that you screw on the bash and sproket straight on)HELP PLEASEPhil Quote Link to comment Share on other sites More sharing options...
the judge Posted November 20, 2006 Report Share Posted November 20, 2006 Burns have a spline thing on the drive side crank, the bash goes on that and then a lock ring keeps the bash in place Quote Link to comment Share on other sites More sharing options...
Phil H Posted November 20, 2006 Author Report Share Posted November 20, 2006 the judge said: Burns have a spline thing on the drive side crank, the bash goes on that and then a lock ring keeps the bash in place ok cheers but im not talknig about middleburns. Im talknig about nearly all the cranks on tarty. Surely they arent all screw on bash and sprocket?!Phil Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted November 20, 2006 Report Share Posted November 20, 2006 Pretty much are on Tarty'.Either front freewheel, or screw-on bash and sprocket. Quote Link to comment Share on other sites More sharing options...
Phil H Posted November 20, 2006 Author Report Share Posted November 20, 2006 Dan6061 said: Pretty much are on Tarty'.Either front freewheel, or screw-on bash and sprocket. Ah i see - cheers matePhil Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted November 21, 2006 Report Share Posted November 21, 2006 A Middleburn bashring will only fit Middleburn cranks or I think, the old XTR cranks, thats if it's a centre spline system. Just a word of warning but Yeh, basically everything on Tarty minus the Burns have scren on freewheel/cog/bash system, it's like, the standard in trials these days. Quote Link to comment Share on other sites More sharing options...
Phil H Posted November 21, 2006 Author Report Share Posted November 21, 2006 onza kieron said: A Middleburn bashring will only fit Middleburn cranks or I think, the old XTR cranks, thats if it's a centre spline system. Just a word of warning but Yeh, basically everything on Tarty minus the Burns have scren on freewheel/cog/bash system, it's like, the standard in trials these days.Cheers man so im looknig at these cranks currently: http://www.tartybikes.co.uk/product.php?id=156They would work with preety much any front freewheel and bash bought from tarty? But what else would I need - some kind of locking device?Phil Quote Link to comment Share on other sites More sharing options...
RobinJI Posted November 24, 2006 Report Share Posted November 24, 2006 Nah, that's all you'd need. A bash and freewheel/fixed sprocket. Because of the direction they screw on the motion of the cranks tightens them every time you pedal, so you don't need a lock-ring. Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted November 24, 2006 Report Share Posted November 24, 2006 Like he said^ Just its a bitch to get off. But yeh, cranks, bash (optional) and fixed cog/freewheel is needed, unless you go the the tensile bashring which is also a spider for 5 bolt compact drive, which I just so happen to prefer, personal preference I guess. Quote Link to comment Share on other sites More sharing options...
