Avid Bb7 Help
Joey B
I going to be getting a BB7 soon and saw this on eBay. BUt its described as a Road front brake and the disk looks different to others i have seen. Will it still be suitable for trials use???
Joey B
Joey B? :blink:
Yeah, that's the right brake (Y) . It's the same as last years model, just with a 'roundagon' rotor.
You are making a very wise decision, also, my like-named friend; Avid BB7's are amazing disc brakes...
Cheers,
Joe.
Surely you could run it, just the bite point would be further on the lever? couldn't you just settle this by backing the pads off fully, or am I missing the ENTIRE problem...
roady and bmx levers have different pivot placments, so that means they pull less cavle, to compensae bmx, cantilever and roady brakes have different ratios too sto stop the brake feeling really spongy.
If you run a roady disk with a normal lever it will feel really solid at the lever and have less power. You could run a speed dial lever in its lowest setting though.
Ali summed this up perfectly about the lever pull.. However i'm going to confuse you all again :P
Now i can't remember who makes this, i have a feeling its Avid (although i can't find it!) there is a special little roller type thing (No not the one for rear mechs! bit like that though) which to put on instead of a noodle on a V brake which enables you to run the Vee with a drop bar style brake (which pulls the same as a canti brake lever).. Now.. i know mechanical discs don't run noodles like Vee brakes do, however you could still insert one of these down by the caliper and hey presto.
Personally.. i'd say stuff that and get the right thing to begin with! :lol:
Yep i agree though many of these tips/bodges may work, theres nothing like keeping it simple. So does anyone know where i can get a MTB one. Yes i have google'd it and i can't find a price that is anywhere near to CRC's £50 (N) .
Thanks
Joey B
Edited by fugigas
