Ryan Blackwell Posted November 16, 2006 Report Share Posted November 16, 2006 hi there can some one help me with bleeding a magura without a bleed kit but using tap water thanks guys Quote Link to comment Share on other sites More sharing options...
roly Posted November 16, 2006 Report Share Posted November 16, 2006 www.trials-forum.co.uk/index.php?showtopic=65710&hl=bleeding+mag Quote Link to comment Share on other sites More sharing options...
Darren Nash Posted November 16, 2006 Report Share Posted November 16, 2006 To bleed a magura simply fill up a bucket or container of water enougth to submurge the whole brake .Secoundly get an alain key and uncrew the bolt on the caliper make sure you pull the lever a couple of times to get rid of all the exsiting fluids. lastly hold the whole brake under the water and pull the lever a few times till it is full. Now tighten up the bolt whilst holding the brake under the water and then refit brake to your bike. Quote Link to comment Share on other sites More sharing options...
Rupertbear Posted November 17, 2006 Report Share Posted November 17, 2006 (edited) Make sure the TPA is right out before you start) i used a bucket of distiled water took out both the alan keys submerged the whole brake under the water and pumped the lever until all the air was out of the brake....Keep the brake under the water while you put the alan keys back in. you may need 2 goes to get all the water out. Edited November 17, 2006 by Rupertbear Quote Link to comment Share on other sites More sharing options...
