T-OM Posted November 16, 2006 Report Share Posted November 16, 2006 http://www.tartybikes.co.uk/image.php?imag...etchaintugs.jpgAre gusset chain tugs any good, are they better the onza? Quote Link to comment Share on other sites More sharing options...
Andrex Posted November 16, 2006 Report Share Posted November 16, 2006 Whats meant to be good about them they do the exact same job as the onza ones, just probably a different shape. Buy something that has to be upgraded! Quote Link to comment Share on other sites More sharing options...
T-OM Posted November 16, 2006 Author Report Share Posted November 16, 2006 (edited) Whats meant to be good about them they do the exact same job as the onza ones, just probably a different shape. Buy something that has to be upgraded! onza are made out of aluminium and the gusset are made out of steel. Edited November 16, 2006 by T-OM Quote Link to comment Share on other sites More sharing options...
poopipe Posted November 16, 2006 Report Share Posted November 16, 2006 onza are made out of aluminium and the gusset are made out of steel.have you broken the onza ones ? if not there's no need to replace them. if you have busted them then I'd advise snail cams (assuming you have the necessary holes) cos you don't hit them when you land on your dropouts Quote Link to comment Share on other sites More sharing options...
T-OM Posted November 16, 2006 Author Report Share Posted November 16, 2006 have you broken the onza ones ? if not there's no need to replace them. if you have busted them then I'd advise snail cams (assuming you have the necessary holes) cos you don't hit them when you land on your dropoutsI have a t-mag so i can fit snail cams on it Quote Link to comment Share on other sites More sharing options...
poopipe Posted November 16, 2006 Report Share Posted November 16, 2006 I have a t-mag so i can fit snail cams on it that's a bit of a sod - you can put em on a t-pro (but not on my t-lite )i'd just buy the cheapest and smallest ones i could find to be honest - if you're the kind of rider that kills them you'll kill them regardless of how fancy they are. Quote Link to comment Share on other sites More sharing options...
T-OM Posted November 17, 2006 Author Report Share Posted November 17, 2006 I have a t-mag so i CAN NOT fit snail cams on it EDIT Quote Link to comment Share on other sites More sharing options...
