lil wilkins Posted November 16, 2006 Report Share Posted November 16, 2006 i've just look on tartybike and notice that the new hope mono trial is outit a bit early to ask but is there any reviews on it Quote Link to comment Share on other sites More sharing options...
Trialsbikenut Posted November 16, 2006 Report Share Posted November 16, 2006 Hi i don't think there will be any reviews on the brake yet, as its just been put on tarty, it looks awsome, i would say your best bet is to email them and ask them what its like as they will most probably of put it on one of their bikes to see what its like thanks trialsbikenut Quote Link to comment Share on other sites More sharing options...
lil wilkins Posted November 16, 2006 Author Report Share Posted November 16, 2006 Hi i don't think there will be any reviews on the brake yet, as its just been put on tarty, it looks awsome, i would say your best bet is to email them and ask them what its like as they will most probably of put it on one of their bikes to see what its like thanks trialsbikenut ok thanks should be getting one next week just wanted to no if they were any good before i got one Quote Link to comment Share on other sites More sharing options...
Trials Maniac Posted November 16, 2006 Report Share Posted November 16, 2006 (edited) Description : This brake was designed specifically for the unique demands of Trials.Lever – Classic Mini lever giving smooth, progressive feel. Split clampfor easy fitting. Integrated master cylinder reservoir for easy bleeding.Adjustable lever reach.Caliper – One piece caliper, machined from solid billet of aluminium. Aswell as reducing weight, this also allows us to make a more rigid caliper,improving the lever feel. Large diameter pistons to give increasedpower. Black caliper with silver bore caps allowing access for servicing.Two aluminium pistons with magnets to hold the pads from disc.Stainless Steel braided hose fitted as standard.Use - Trials. Must not be used for any other purpose.Seems a good and popular brake. I'd go for it mate.... Edited November 16, 2006 by Trials Maniac Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted November 16, 2006 Report Share Posted November 16, 2006 THEY ARE ACE! even work good and a 26" with a 180 rotor! ma mate has 1 of the proto-types with the t.p.a etc ! works emence thats all from me! danny ... Quote Link to comment Share on other sites More sharing options...
Egg Fried Rice Posted November 16, 2006 Report Share Posted November 16, 2006 trials maniac thats the older oneJK Quote Link to comment Share on other sites More sharing options...
Trials Maniac Posted November 16, 2006 Report Share Posted November 16, 2006 trials maniac thats the older oneJKoh ok sorry, I did not know. it was on the hope website so i presumed that was the new one. Sorry Quote Link to comment Share on other sites More sharing options...
Greetings Posted November 16, 2006 Report Share Posted November 16, 2006 Uhh, what's the difference between the 06 and 07? The caliper is exactly the same, and I'm almost sure they haven't changed the master cylinder diameter? In that case, what's the point? Quote Link to comment Share on other sites More sharing options...
dan the trials man Posted November 16, 2006 Report Share Posted November 16, 2006 i was looking at them i might buy one if the bike i want to put them on is a 26 should i get the 200mm version the bike i am buying comes with magura hydrolic vs front and back would you recomend puting a disk on the front. Quote Link to comment Share on other sites More sharing options...
JT! Posted November 16, 2006 Report Share Posted November 16, 2006 Isn't there some sort of weird and wonderful new leaver? Quote Link to comment Share on other sites More sharing options...
matt rushton Posted November 16, 2006 Report Share Posted November 16, 2006 (edited) Isn't there some sort of weird and wonderful new leaver?[attachmentid=8189][attachmentid=8190]The first is the normal lever the seconde is the moto.Matt Rushton Edited November 16, 2006 by matt rushton Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted November 16, 2006 Report Share Posted November 16, 2006 i thought the mini lever had changed too Quote Link to comment Share on other sites More sharing options...
Mr-BT Posted November 17, 2006 Report Share Posted November 17, 2006 why dont you check it out on tarty then, the new lever looks really mintDescription- NEW updated Mono Trial brake from Hope!- Completely revised lever is now stiffer than before, and has a more rounded lever blade which is much more finger-friendly!- New colour scheme for 2007 too, now with silver lever and caliper body, with black lever blade, top cap and bore caps.- New rotors also have more arms and a deeper braking surface for increased stifness and braking power.- Upgraded\' hydraulic piston ratios gives 54% more mechanical advantage and thus far more power than any standard disc brake featuring a similar sized rotor. - 180mm rotor offers even more power than the standard 160mm rotor version, and therefore recommended for stock (26\" wheel) bikes.- Large venting holes helps keep the rotor cool and prevent the pads from glazing over and causing a reduction in brake power/performance. - Fitted as standard with stainless steel braided hosing to help prevent hoses becoming kinked or pulled out of the lever/caliper whilst riding/crashing! - International Standard (IS) caliper and 6-bolt rotor means the system is compatible with most disc hubs and frames/forks on the market (if you are unsure, please contact us for advice). - Right hand lever supplied as standard, but can be fitted with a left hand lever. Please enquire for details.- Weight 444g including full length hose and, all mounting hardware. cheers nick Quote Link to comment Share on other sites More sharing options...
ramps Posted November 17, 2006 Report Share Posted November 17, 2006 This wonderful lever you may be refering to is probably the 'carbon' lever, I don't know anything about it really, just that it does exist. Quote Link to comment Share on other sites More sharing options...
jim-p Posted November 17, 2006 Report Share Posted November 17, 2006 they look sex but aren't they a bit expensive at the moment if it was me i'd wait until the price goes down a bit but it's up to you if you want to buy one now depends on if you have the money i know i don't. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 17, 2006 Report Share Posted November 17, 2006 Uhh, what's the difference between the 06 and 07? The caliper is exactly the same, and I'm almost sure they haven't changed the master cylinder diameter? In that case, what's the point?The lever is completely revised, as is the piston bore quality - much smoother now.i thought the mini lever had changed tooYep, see our site for pics!they look sex but aren't they a bit expensive at the moment if it was me i'd wait until the price goes down a bit but it's up to you if you want to buy one now depends on if you have the money i know i don't. The price is at the RRP - they won't go down until the next series of brakes are released. Quote Link to comment Share on other sites More sharing options...
basher Posted November 17, 2006 Report Share Posted November 17, 2006 (edited) it looks just like the new hope moto brake. which you can get with a new vented rotar but will empty your pocket at 209 squids. is it the same brake or is there an actual difference. but for the brake at 160 quid it seems like rape when you can go and get a 203mm avid bb7 for about £100 and they are f**king amazing brakes, or even a 180 is shit hot even on a 26'. just seems silly to pay extra for a brake that wont preform any better and is harder to set up and theres more to go wrong oh well perhaps its just me thats thinks that. Edited November 17, 2006 by andy h Quote Link to comment Share on other sites More sharing options...
RobinJI Posted November 17, 2006 Report Share Posted November 17, 2006 The moto and the Mono trials are completely different breaks. the caliper on the moto has a different piston diameter. The Moto uses the new moto lever with a biting point adjuster, while the mono trials uses the revised mini lever which is a standard lever, just with a new shape to help feel and weight.The new ones look nice, it looks like they haven't addressed the flexy caliper issue though. Hopefully the new lever bites a little earlier as well, on the old ones you had to have the reach silly far out for them to bite in the right place. Quote Link to comment Share on other sites More sharing options...
